Thread: Button handbrake noise!
  1. Button handbrake noise!
    Oct 2006
    To anyone who have a New passat.
    Do you get a grinding noise whenever you put on the button brake?
    My started to make that noise and i just wonder if this is normal?
    Apr 2006
    Kent
    It does seem to be the way it works. I sent mine in as I was concerned about the horrible sound it made, but I was told that that was normal.
    blackie Guest
    If you think about it Frank, with a traditional handbrake, where you pull the lever, you are pulling on a mechanical link and thereby you are doing all the work. With the electronic handbrake, it's exactly that: electronic. So in other words, there's a motor that is whirring away in order to engage/disengage the brake.
  4. cheers
    Oct 2006
    Thanks for that blackie.
    Youhave a point there. I have made enquiries about it and that is suppose to be quite normal.
    Its just ashame, because with all this modern technology you would
    have though they can make a motor much quieter!"!?
  1. Handbrake Lever
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2009, 10:33 PM
  2. Electronic Handbrake Activation.
    By DocL in forum Passat - Archive Topics
    Last Post: 16-05-2007, 01:36 PM
  3. A6 Handbrake Light glowing with engine off
    By lcs in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-03-2007, 04:58 PM
  4. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
  5. Handbrake rattle
    By IMR in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-06-2006, 11:14 AM
