Thread: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
    May 2007
    Are these chips really that good? Im tempted to do mine.
  2. Re: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
    Apr 2007
    Lancashire
    I think the OP meant the VP37 fuel pump connector for a tuning box.
    The very early ones had a DIN connector, with later models having a 'D' shaped 8pin, moving onto a 10pin.
    If you follow the bundle of wires coming from your fuel pump you will come to the connector, it is approx in the middle of the engine bay, below and behind the pump.
    I have tried a few different varieties of German 'ebay' chips on my old VE 110, and there is a vast difference between the best and the worst.
    At worst some simply had altered pump mapping, and were effectively a tuning box on a chip, some of the better variety were altering a minimum of 10 or more maps giving more power in a safe non-piston melting manner.
    A cheap DIY ebay 'chip' is pot luck, if you buy one, stick with a chip or remap from a highly recommended, or established, proven company.
    If you dont get a tuning box, i would go for some used, ebay, 'old school' Wetterauer chips or similar, or a 'live' remap for max power.
    If you are DIY'ing, you will need to check your chip/s type, this should be possible with model and ECU number/software type, or you can always pop open your ECU and look.
    You may or may not need socketts fitting.
    If you want a lot more power and are prepared to pay, i would go for nozzles, turbo and a proper remap using your existing maps.
    You will need to plan for a stronger clutch, and let the tuner know exactly what you want or you may pay good money on a 'low power', safe, non clutch destroying power levels that could be achieved with a £10 used tuning box.
  3. Re: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
    gintoons Guest
    Quote Originally Posted by fludor View Post
    I just bought a pair of chips from sjk digital for my audi 80 and i can say is like i'm driving a diferent car right now, but i have a problem and i don't really know if is from the chips or is just a something wrong with my car. As i sayd the car is running good but after 2 minutes from the moment the engine was started i get flashing glow plug light. If i stop the engine and start it again i get the same flashing light after 2 minutes. Is it any way to fix this or do i have to return the chips, cause i've been trying to call them but no answe, also they don't answer to my emails.
    Thank you and all the best
    PS
    I've done a vag scan and it didn't find any error. Tomorow i will try with the original chips again to make shure is not a problem with the car
    I have the same problem with sjk digital chips,-flashing light after aprox.1.5 minutes.
    If You have any new expierience about this flashing,please let me now.
    Thank you!
  4. Re: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    PS
    you have fitted a cheap unit, best to remove it and pay for a quality tunning box, the 8 or 10 pin plug is the wire coming from the Diesel pump, it is round on the 80 so most tunning boxes don't fit, you will have to make sure it is a round connector you need.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  5. Re: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
    Mar 2007
    Quote Originally Posted by dean warren View Post
    I agree with you in only one way... yes i've bought cheap cips and i was expected to have problems, the good thing i'm comunicateing with the guy who sold me the cips and he is working right now to fix the problem. I do not agree with you when you say i should buy a TUNING BOX. You see, the tuning box is only tricking the ECU about some data received from the sensors thing that i don't really like, and i'm not the only one haveing the same opinion about the tunning boxes.
    I will go on for a while with the modifications made by this guy and if i can't fix the problem i'll replace the cips with the original ones.
    @gintoons if i have any new i'll let you konw, the guy from sjk digital is a bit slow with the emails but he said he's going to fix it.
    Thank you for your answer
  6. Re: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
    Apr 2007
    Lancashire
    I have a pair of hi/lo SJK digital plcc32's for my afn in a drawer somewhere.
    If i have time, I will see if i can compare them with the original maps.
  7. Re: I want to chip my 80 beast, where is the special plug (8 PIN 10 PIN) L reg
    #17
    Mar 2007
    Quote Originally Posted by ini View Post
    Please do!!! Soon i will get my eprom programmer so i will also sent the dumps from the eproms i have here.
  1. Plug in Chip Audi A3 110 sport?
    By madog in forum Audi A3 - Archive Topics
    Last Post: 05-02-2008, 12:32 AM
  2. recommend plug n play chip for 1.9 tdi 06 a4
    By redaudia4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-11-2007, 12:51 AM
  3. The Beast
    By spencer in forum New Member Introductions
    Last Post: 25-10-2007, 08:19 PM
  4. Plug in chip any good??
    By L90OOK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-08-2007, 08:32 PM
  5. New Plug in chip for 1997 TDI
    By redevo1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-02-2007, 07:44 PM
