Thread: TDI Alternator Problem
Results 1 to 10 of 13
  1. TDI Alternator Problem
    Apr 2007
    I have a 51 plate 90bhp TDI Golf (70k miles) that I think has an alternator problem.
    A couple of times recently when driving at night I noticed the head lights were a bit dim for the first mile and then at full brightness after that. Yesterday I checked volts on battery at start up which were 12V and then after about a mile when lights had reached full brightness the volts were at 14V with engine still running. So alternator seems to work (after one mile), as car starts OK and I haven't noticed any other problems. So my question is, is my Alternator about to fail or is there something else that could be causing the problem.
    Also I got a quote of £185 +VAT for an exchange 120A Bosch alternator from my local VW specialist, does that sound about the right price.
    Paul
  2. Re: TDI Alternator Problem
    135 Post(s)
    2042 Post(s)
    Try starting the car and revving it to say 2K for a moment and see what the charge says. The price sounds a little cheap but OK, for a genuine unit (2 year guarantee) it would be a little more.
  3. Re: TDI Alternator Problem
    Apr 2007
    After a bit more investigation have discovered that alternator starts charging when engine revved to 2.5K and happens every time engine is started whether hot or cold.
    Paul
  4. Re: TDI Alternator Problem
    135 Post(s)
    2042 Post(s)
    Just done a 2002 V6 4 Motion like that today, it didn't start charging until 2200 rpm. A new alternator fixed it but on a 4M you have to take the whole front of the car off.
  5. Re: TDI Alternator Problem
    Apr 2007
    Having had a quick look at the position of my alternator it looks a bit buried in the engine bay, how many hours of labour am I likely to be charged by a VW specialist to change it as I presume various bits and pieces have to be removed to get access.
  6. Re: TDI Alternator Problem
    135 Post(s)
    2042 Post(s)
    What engine code?
  7. Re: TDI Alternator Problem
    Apr 2007
    When you say engine code, do you mean the engine number?
    If so I will check in the morning and post reply.
  8. Re: TDI Alternator Problem
    135 Post(s)
    2042 Post(s)
    Yes, that is what I mean but only the three letters.
  9. Re: TDI Alternator Problem
    Apr 2007
    Engine code is ALH.
    At the risk of looking a bit stupid, I thought that the ignition light came on if the alternator isn't charging, is that true or is it only when the battery volts start dropping?
  10. Re: TDI Alternator Problem
    135 Post(s)
    2042 Post(s)
    You would think so but in three weeks I have had two Golf V6 4-M's with a faulty alternator and not showing a warning light.
  1. Alternator problem?
    By delboy001 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-01-2008, 03:34 PM
  2. alternator
    By salty in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-12-2007, 02:24 PM
  3. 1.9 tdi alternator
    By otis_b in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-09-2007, 08:51 AM
  4. Alternator
    By nkosi bob in forum Passat - Archive Topics
    Last Post: 17-07-2007, 09:09 AM
  5. alternator
    By gibby45 in forum Passat - Archive Topics
    Last Post: 09-11-2006, 10:08 PM
