Thread: '98 Polo running on only 2.3 cyclinders!
  1. '98 Polo running on only 2.3 cyclinders!
    Can anybody help, i'm all out of ideas?
    My Polo 1.4 (AEX engine not 16v) is idling roughly and very down on power and up on fuel consumption. If I remove the plug leads on cyclinders 2 and 4 it makes virtually no difference to the idle speed at all. It seems to be running on about 2 cylinders quite amazingly.
    I've checked and cleaned the throttle body.
    Replaced HT leads, checked cap and rotor.
    Had it plugged in to the diagnostics and it reports no faults.
    Looked around for air leaks and found none.
    Its done 48K so i'd be surprised if valves are burnt out already. If anyone has any suggestions i'd be very grateful
    Thanks a lot,
    Will.
  2. Re: '98 Polo running on only 2.3 cyclinders!
    131 Post(s)
    1976 Post(s)
    Have a compression test done but that isn't the version prone to burning valves. Have you replaced the plugs?
  3. Re: '98 Polo running on only 2.3 cyclinders!
    Yes I changed the plugs as a first step, forgot to mention that. I'll try and get the compression test done tomorrow.
    Thanks,
    Will.
  1. Running on Veg Oil?
    By L90OOK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2008, 10:03 AM
  2. polo country 1989 running problems
    By syncroman in forum Polo - Derby - Lupo - Fox
    Last Post: 08-03-2008, 02:43 PM
  3. Poorly Polo running a temperature
    By side-show-bob in forum Polo - Derby - Lupo - Fox
    Last Post: 13-01-2008, 02:33 PM
  4. 1997 Polo 16v Poor running
    By dom77 in forum Polo - Derby - Lupo - Fox
    Last Post: 30-11-2007, 03:23 PM
  5. Running like a pig!
    By sunmotors in forum Archive posts
    Last Post: 01-04-2006, 05:06 PM
