Thread: Passat engine tappety
  1. Passat engine tappety
    Oct 2006
    Hi, i have a 1998 1.8 20V passat its only covered around 97K miles and has been serviced every 10K miles...it is currently due a service.
    The problem is that at idling speed there is a tappet sound from the top of the engine, it goes away sometimes and other times it comes back.. but the car drives with no problem it it cant be heard whe driving or revving.
    Any help would be appreciated
    Oct 2006
    Particularly if the problem is more prevalent on hot idle and/or cold startup than an any other time, I suspect the cam chain tensioner or leakage of either its adjoining cam seals or its mounting gasket. The latter problem normally brings on a burning oil odor, as well.
  1. 01 Passat TDi Engine Workshop! Message??
    By alba_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-02-2010, 03:04 PM
  2. Passat Tdi engine(?) vibration.
    By alba_tdi in forum Archive posts
    Last Post: 29-08-2007, 12:00 PM
  3. OBDII and the PASSAT 1.8 engine
    By jfdale in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 12:36 PM
  4. 02 Passat 18T SE 100k engine out
    By Stix in forum Passat - Archive Topics
    Last Post: 01-03-2007, 01:01 AM
  5. 02 Passat 18T SE 100k engine out
    Last Post: 25-02-2007, 11:39 PM
