Thread: Throttle Re-Adaption - Polo 1.4
  1. Throttle Re-Adaption - Polo 1.4
    Oct 2006
    Hi All
    Can anyone help me with re=adapting the throttle body on a 2000 Polo 1.4 (AHW).
    I had to replace the engine speed sensor, and while fuel system was off I cleaned the throttle body. I am trying to readapt it with VAG-COM, when I go to group 098 I can hear the motor start, and the first display seems OK, then display changes and I get ERROR in adaption mode window. Pot voltages seem OK and throttle does not seem to be sticking.
    No error codes in engine module.
    Any ideas?
    Stuart
  2. Re: Throttle Re-Adaption - Polo 1.4
    Quote Originally Posted by Stue View Post
    Hi All
    Any ideas?
    Stuart
    try this link stuart it worked on my vag com.
    http://www.ross-tech.com/vag-com/cars/throttlebody.html
  3. Re: Throttle Re-Adaption - Polo 1.4
    Oct 2006
    Thanks for the link, but that is what I am doing.
    VAG-COM seems to be doing the right thing, it must be a fault in the electrics.
    Stuart
  4. Re: Throttle Re-Adaption - Polo 1.4
    Aug 2010
    stoke-on-trent england
    IF YOUR ECU IS MARELLI TRY THIS . TURN ON THE IGNITION {DONT START THE ENGINE}FLOOR THE THROTTLE AND HOLD FOR ABOUT 20SECONDS THEN TURN OF THE IGNITION.WORKS ON MK3 GOLF 1.4&1.6 WITH MAGNETTI MARELLI ECU.GOT THIS OFF A RENO-PUG SITE AND TESTED ON MY GOLF .O.K
  5. Re: Throttle Re-Adaption - Polo 1.4
    131 Post(s)
    1976 Post(s)
    The whole point of throttle adaptation is that it learns the rest and maximum movement positions of the throttle valve idle stepper motor and feeds back the values from the potentiometer so that the ECU knows the values and can use them to control the idle. It cannot do this if it adapts at WOT.
  1. Throttle Body
    By Fibreron in forum Passat - Archive Topics
    Last Post: 26-12-2007, 10:51 PM
  2. is it a throttle problem???
    By pa o rahilly in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2007, 10:05 AM
  3. throttle problem
    By macker in forum Golf MK4 - 1999 - 2004
    Last Post: 03-10-2007, 06:14 PM
  4. Throttle sticking when below 0
    By lilsarah in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2007, 10:49 AM
  5. throttle responsiveness
    By nibbzy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-04-2007, 02:32 PM
