Thread: Remove rear light cluster - Polo 2003 (03) 1.4S 5DR
  1. Remove rear light cluster - Polo 2003 (03) 1.4S 5DR
    Cheshire, UK
    The off-side brake light has failed on my wife's polo.
    I pulled the trim back tonight on the assumption that it would be a simple job.
    It seems not!
    I can see that the cluster assembly is retained by a black plastic wing nut. When this is unscrewed, the M6 stud is visible, and the cluster is loosened. However it does not pull free.
    I guess there be something else to release or some lugs that engage in the body and the cluster must be pulled in a certain direction to release it.
    I didn't want to get brutal with it and snap any such lugs off!
    Can anyone enlighten me in the procedure for removing the cluster assembly please? (Scans for a manual would be helpful if possible!)
    Many thanks,
    Jon
  2. Thumbs up Re: Remove rear light cluster - Polo 2003 (03) 1.4S 5DR
    Cheshire, UK
    I worked it out... Here's the answer...
    Unscrew the black plastic wingnut in the back of the light cluster (you have to pull back the trim in the boot to get to this.
    The cluster has two spring-loaded lugs on the outer edge.
    The release the cluster, lift the cluster up a couple of mm (against the spring pressure) and pull backwards - the cluster will come away easily - if it does not release easily you have probably not lifted it enough.
    After you have changed bulb, make sure that the gaskets are in place, otherwise you will end up with a small swimming pool in the boot!
    3 0 0
  1. How To: Remove the instrument cluster?
    By Jdub in forum Golf MK1 - 1974 -1984
    Last Post: 28-03-2008, 06:59 PM
  2. Cracked rear light cluster
    By shovels in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-10-2007, 01:25 PM
  3. wire colour wanted rear light cluster Passat
    By BARN OWL in forum Passat - Archive Topics
    Last Post: 25-07-2007, 07:47 PM
  4. Removing Instrument Cluster On 2002 Golf V5 To Remove Emissions Warning Light Bulb
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-06-2007, 06:02 PM
  5. How to remove dash cluster?
    By JiminBahrain in forum A8 - S8 - V8
    Last Post: 03-06-2007, 06:39 PM
