Thread: Heater not blowing any air?
  1. Heater not blowing any air?
    Mar 2009
    Hi I have a 1997 A4 1.9 Tdi and I'm having some problems with my windscreen misting up.
    I don't have manual controls its got a digital climate control and when put on the hottest setting hot air will pass through the vents but only when I'm travelling at speed and not when stationary, there seems to be no pressure coming from the motor. This is not an intermittent problem its always like this. Could it simply be a blockage or something?
    Does anyone have any suggestions on how to fix this, cheers.
  2. Re: Heater not blowing any air?
    Dec 2008
    East Preston, West Sussex
    Does sound very much like the variable speed fan has failed.
    Check the fuse to make sure that it has not just blown.
    I know you get some air through at speed, but also check that the pollen filter has been replaced recently, as this will also put an additional strin on a new fan, if you have to fit one.
    If you can get someone to scan your car with VAG-COM, this may reveal a fault code pointing to the fan or similar.
    John
    2005 A4 B6 Avant 1.9 TDI 130 Sport (6)
  1. Please Help Heater Display Working But No Air Blowing ???
    By JIGGY C in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2009, 07:19 AM
  2. Heater only blowing hot air on passenger side
    By stuartt0712 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 08:16 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Heaters Blowing Cold air! Head gasket or Heater Valve?
    By yellow-160 in forum Golf MK2 - 1984 - 1992
    Last Post: 08-06-2008, 04:29 PM
  5. Mk4 Golf fan heater / air con
    By glyn in forum Golf MK4 - 1999 - 2004
    Last Post: 19-11-2007, 10:33 PM
