Thread: Golf GT Sport DSG
  1. Golf GT Sport DSG
    Hi all,
    Just wondering if anyone has a DSG VW or automatic as I've got a question.
    I've had my golf for over a year now and the last few weeks its been doing something weird. Every morning I get in my car the brake pedal is solid - once I start the engine it slowly sinks again as normal but at first it's solid when I put my foot on it to start.
    Any ideas guys?
    Dan
    www.traffictalk.co.uk
  2. Smile Re: Golf GT Sport DSG
    Jul 2008
    Hi Dan
    Check your waterpump and cambelt, as had one come in yesterday with the same problems as you have described, what i was informed from the RAC Man towing it was, that the waterpump exploded and the ball bearing shot into the cambelt (Timing Belt) hence ripping it.
    Kind Regards
    Matt
    Auto Surgery UK
  3. Re: Golf GT Sport DSG
    May 2008
    How would a torn timing belt affect the break pedal in the manner described?
  4. Re: Golf GT Sport DSG
    Up North
    Quote Originally Posted by TrafficTalker View Post
    Hi all,
    Any ideas guys? Dan
    If you pump the pedal a couple of times with the engine turned off, the pedal hardens as the vacuum in the servo is exhausted. I also notice the same effect with the engine running on my Passat, which has the electronic handbrake and the auto-hold brakes (when they are actuated) . Do you have this option on your Golf?
    The other option is a slow vacuum leak from the servo. I can't imagine that it is leaking from any of the vacuum pipework because I would expect the servo to have a non-return valve.
    The timing belt option is more complicated, 'cos with a torn belt the engine ain't going to run (or even survive) and there is no connection with the brakes that would cause the symptoms you describe.
    Either someone is yanking your chain (perish the thought), or he knows of some multi-dimensional psychic link between the cambelt and brakes; it probably involves some sort of fracture in one of the starboard warp plasma conduits and the subsequent emission of thoron radiation from the single diaphragm double-dipole flange retractor mechanism which is initiated whenever Jupiter is ascendent in Capricorn and your wife/GF/significant other has bought green shoes in the last week. The mechanism is supposed to drain all of the crystal energy from the throstle-wick, but a side effect is that it makes the brake pedal go hard. Only on Tuesdays though, which I've never really understood properly. Maybe you should have the car looked at by a psychic healer. I know a good one who paints the car with Heinz baked beans and chicken soup to cure difficult problems like this. She also does MOT tests for only £9.99, which I think is an absolute bargain, even if the beans do cost £299 a tin.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  5. Re: Golf GT Sport DSG
    Hi Dan
    My car GT Sport 170 manual, does exactly the same... did you sort the problem???
  1. The New Trim Golf "GT Sport"
    By Tsi170-LOver in forum Golf MK5 - 2004 - 2009
    Last Post: 18-02-2008, 11:19 PM
  2. GOLF GT SPORT - 2.0TDI - HIRE CAR - Review
    By RickT in forum Chat - Anything with wheels
    Last Post: 01-10-2007, 05:03 PM
  3. Golf MkV (GT Sport 140 TDi) Info Please.
    By Wazza_G in forum Golf MK5 - 2004 - 2009
    Last Post: 08-09-2007, 10:26 PM
  4. VW Golf 1.9 TDi Sport - MK5
    By geocTDi52 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-06-2007, 05:01 PM
  5. Volkwagen Introduces New Golf Gt Sport Trim
    Last Post: 27-05-2007, 07:37 PM
