Thread: Tyre Pressure
Results 1 to 10 of 11
  1. Tyre Pressure
    Ive just bought a passat 2000 plate, 1.9 tdi SE. I was wondering what the recommended tyre pressue was for it.
  2. Re: Tyre Pressure
    Jun 2006
    UK, Mids
    It should be inside the fuel flap door, it varies upon wheel size etc....
  3. Re: Tyre Pressure
    thanks mate
  4. Re: Tyre Pressure
    Jul 2008
    Blackburn
    I've looked at the recommended tyre pressure on the inside of the petrol cap, but it's in metric, and all of the garages I use have imperial measurements on the tyre inflators, ie. lbs square inch. Can anyone give us a rough idea as to what I should have the tyres at ?
    My car is a 1.8 Passat T reg petrol.
    I've always had pressure on my tyres on other cars I've had, of a similar size, at about 30/32 lbs per square inch.
    Whenever I go to get some fresh tyres for the cars I've had, of similar size, the tyre place always pump them up to 30 lbs/ inch.
    Thanks.
  5. Re: Tyre Pressure
    Jul 2007
    I`d always check your tyre pressures yourself, as I recently had a set of tyres fitted by a "professional" national outfit, who underinflated all of them by 6 PSI. This was despite the correct pressures being on the inside of the filler flap.
    When I went back and questioned them, the "fitters" (can`t think of anything more descriptive which I could put in print) merely told their boss that "thats what we always put in tyres of that size"
    Well, thats alright then.....
  6. Re: Tyre Pressure
    i was running 19" on my last vectra cdti and the reccomended was .....38-40 psi
  7. Re: Tyre Pressure
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by frank-59 View Post
    Thanks.
    Bar psi
    1.5 21.8
    1.6 23.2
    1.7 24.7
    1.8 26.1
    1.9 27.6
    2 29.0
    2.1 30.5
    2.2 31.9
    2.3 33.4
    2.4 34.8
    2.5 36.3
    2.6 37.7
    2.7 39.2
    2.8 40.6
    2.9 42.1
    3 43.5
    here you go
    Nothing to see here, move along..
  8. Re: Tyre Pressure
    ive just got some 225/40/18 and am looking for the correct psi, have you any info on them or would it be the same at the 2.5--- 36 ?
  9. Re: Tyre Pressure
    May 2006
    A quick conversion from bar to psi :-
    1bar = 15psi
    As most pressure gauge are not that accurate, its more important to get the same reading on the tyres across the axles ie. the front tyres are the same pressures according to your pressure gauge and the same goes for the rear tyres.
    Another factor is the air temperature - cold weather and the tyre pressure will be lower, hotter weather and the tyre pressure goes up. So if you take a pressure reading first thing in the morning it will be lower than a pressure reading in the afternoon after a long run.
  10. Re: Tyre Pressure
    Jul 2008
    Blackburn
    Quote Originally Posted by Hex69 View Post
    Bar psi
    1.5 21.8
    1.6 23.2
    1.7 24.7
    1.8 26.1
    1.9 27.6
    2 29.0
    2.1 30.5
    2.2 31.9
    2.3 33.4
    2.4 34.8
    2.5 36.3
    2.6 37.7
    2.7 39.2
    2.8 40.6
    2.9 42.1
    3 43.5
    here you go
    Cheers for that info Hex.
    The recommended pressures on the filler cap make a bit more sense now. It says between 2.0 to 2.2 depending on load in car.
    So, I wasn't that far off by guessing about 30 psi.
  1. Tyre pressure help please
    By minimonte in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-01-2008, 05:12 PM
  2. Tyre Pressure - 03 Passat
    By kavassery in forum Passat - Archive Topics
    Last Post: 31-08-2007, 12:03 AM
  3. Touran Tyre Pressure
    By aussie in forum Touran - Sharan - Caravelle
    Last Post: 10-07-2007, 05:06 PM
  4. Just gone to 17" what should my tyre pressure be?
    By ldormon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2007, 08:34 PM
  5. Tyre pressure gauge
    By Mav2006 in forum Archive posts
    Last Post: 28-03-2007, 07:32 PM
