Thread: cambelt change on tdi
  1. cambelt change on tdi
    Oct 2006
    bristol
    hi there i have a 2001 passat tdi auto with 130000 miles on the clock,
    the cambelt was changed at 124000 miles,
    WHEN WILL IT NEED DOING AGAIN as i cant find any refrence to this. Also what should i do on a 130000 mile service,
    sorry but i normally work on vw tye 2 campers
    london/ UK
    Hi, you do not say the engine code as it must be taken into consideration for somme TDI built until 2001. After 2001MY-> replacement every 60.000miles and cambelt tensioner pulley must also be replaced, also while you there, replace the water pump and every bolt you take off. Get the whole cambelt kit from a vw dealer. You must take in consideration the way the car has been used. If its been used mainly in town with lots of stops and starts, that puts a lot of strain on the belt and should be taken into account as its wise to replace before its due. Hope this helps.
    Oct 2006
    bristol
    Quote Originally Posted by adamss24 View Post
    DO YO MEAM THE ENGINE NUMBER,
    also whats the best oil to use in the engine and how mutch
  1. cambelt change?
    By AJ84 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-05-2007, 08:15 PM
  2. Cambelt Change
    By wg100 in forum Golf MK2 - 1984 - 1992
    Last Post: 30-03-2007, 09:16 PM
  3. S4 Avant Cambelt Change?
    By Adslock in forum Audi A4 - Archive Topics
    Last Post: 24-03-2007, 11:06 AM
  4. 1st Cambelt change at 180kms????
    By aaaa4aaaa in forum Audi A4 - Archive Topics
    Last Post: 17-01-2007, 06:25 AM
  5. cambelt change 2.5v6 tdi
    By mer in forum Passat - Archive Topics
    Last Post: 30-12-2006, 06:20 PM
