Thread: Alternator Clutch Pulley
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Alternator Clutch Pulley
    Apr 2006
    When I spoke to them they didn't have my year passat listed only upto 2000. They weren't sure if it would fit but when I went through Motor World they checked the serial numbers. I'm not 100% it was gmf who supplied it though.
    All I need now is the pin wrench.
  2. Re: Alternator Clutch Pulley
    Quote Originally Posted by mears1000 View Post
    As a follow on to the ongoing issue of supplies my local VW dealer would sell me the tool needed to remove the pulley but would cost around £25.
    GMF in Llanelli sold me a Sealy SX400 kit for £17 and the pulley was £45 through Motor World in Swansea but supplied by another local motor factors (GMF I think). It's the INA pulley number 535 0005 10.
    Price through any of the VAG dealers was exaclty the same.
    Anyone know the function of a clutch in a pulley? how free should the pulley be in the reverse direction? can the pulley be stripped or lubricated if tight?
  3. Re: Alternator Clutch Pulley
    Apr 2006
    Have a read of this. Anyone used their alternators?
    http://www.qxcomponents.co.uk/tech.pdf
  4. Re: Alternator Clutch Pulley
    Quote Originally Posted by caldirun View Post
    Its there to calm belt flap which has become more prevalent in modern engines, especially diesels.
    The movement should be smooth, its not a sprag clutch like on a push bike, just ball bearings that stop if rotated in one direction. The movement is not loose though, it should never spin.
    Typically when they go, its because the insides are worn, and the ball bearings don't lock any longer, so rotates in both directions.
    Its not a servicable item.
    Hope that helps!
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  5. Re: Alternator Clutch Pulley
    If a siezed pulley causes destruction of the tensioner a solid pulley will do just the same, Cowboys from the sound of it!
  6. Re: Alternator Clutch Pulley
    Yeah, I agree. Didnt read the link before.
    The clutch pulley (OAP) is there for a reason. VAG wouldnt pay to fit it if they didnt need to!!
    They didnt 'decide to replace it'... they went for the cheap option and did away with it...... IMHO.
    The OAP is working all the time, not just slowing down quickly. Since when does road speed have a direct correlation with engine speed?? Theres a thing called 'gears' too!
    2019 Urus, 2020 RS7
  7. Re: Alternator Clutch Pulley
    #17
    135 Post(s)
    2040 Post(s)
    Drop the belt off and carefully hold the internals of the alternator with a screwdriver and the pulley should be solid in the direction of drive and free in the opposite direction with virtually no drag.
  1. Tool for changing Alternator Pulley Wheel
    By Scottyjohn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2008, 09:58 PM
  2. A6 1.9TDI Alternator Pulley
    By johnnywishbone in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2007, 11:46 AM
  3. Is this the Alternator pulley siezing ?
    By cbrpaul in forum Touran - Sharan - Caravelle
    Last Post: 09-08-2007, 09:43 PM
  4. Aux. belt and alternator pulley change/queries
    By dvhttn in forum Passat - Archive Topics
    Last Post: 22-03-2007, 08:29 PM
  5. 03 tdi alternator pulley
    By jeevoe999 in forum New Member Introductions
    Last Post: 26-02-2007, 12:38 AM
