Thread: Alternator Clutch Pulley
Results 1 to 10 of 17
  1. Alternator Clutch Pulley
    Nov 2006
    I've got problems with the power steering, belt is jumping causing rumbling at tick over and whilst turning steering at low speed. After much searching of the forums, it looks like the clutch could have seized in the alternator pulley. What I'm struggling to find out is can this be replaced without pulling the front end of the car forward, as with the timing belt change. The alternator looks accessable at the top right hand side of the engine, so hoping it can be done easily. The car is a 1999 Passat 1.9TDi SPORT 115BHP.
    Can anyone please confirm the repair process and what the specific spline tool is, required to remove the pulley. Also suggestions of where to buy pulley and tool
    MANY THANKS IN ADVANCE
  2. Re: Alternator Clutch Pulley
    135 Post(s)
    2039 Post(s)
    You have to pull the front end forward, release the belt and remove the alternator, at least that’s the way I do it. You also need a special tool to release the pulley.
  3. Talking Re: Alternator Clutch Pulley
    Nov 2006
    THANKS! Did some more searching and found this :
    Tools:
    13mm socket
    13mm deep socket
    10mm socket or wrench
    17mm box wrench
    19mm open end wrench (long length preferred)
    8mm hex bit - 3/8 inch drive
    3 inch extension for 3/8 inch drive
    3/8 inch drive ratchet wrench
    3/8 inch drive torque wrench
    1/2 inch drive ratch wrench or breaker bar
    1/2 inch drive torque wrench
    3212 pin wrench
    19mm socket
    Metalnerd Part MN3400SET - Serrated Alternator Pulley Bit Set
    1 - open the bonnet (hood) and remove the engine cover.
    2 - slide the battery cover to the right side of the and lift off.
    3 - Loosen the nut on the negative terminal and pull off the cable
    4 - Place a rag over the terminal to prevent accidental contact
    5 - Remove the black cap from the large cable retaining nut on the back of the alternator. Remove the nut and take the cable off of the post, then put the nut back on so you don't lose it. Disconnect the connector for the smaller wires. Note the small tab on the wire tie type of retainer below that connector. You can push that small tab towards the long loose end of the retainer and slip that long loose end back through the retainer then remove the cable from the alternator.
    6 - Use a 19mm wrench on the ribbed belt tensioner and move the top end towards the right side of the car then slip the belt off of the alternator pulley.
    7 - slip the 8mm hex bit on the extension through the access hole in the bracket
    8 - counterhold the pulley with the 3212 pin wrench and remove the bolt with the 8mm hex bit.
    You might be able to use a strap wrench to counterhold the pulley, but I have the 3212 so I didn't try.
    9 - Let the fan assembly gently rest at bottom. You won't be able to get it out of the car.
    10 - Use 13mm short socket and remove the bolt with the belt tensioner. Then use a 13mm long socket to remove the bolt below the alternator pulley. The long socket allows your ratchet wrench to clear the alternator pulley and makes it easier to remove the bolt.
    11 - Use a pry tool gently to pry the alternator loose. Once the top was loose I flipped this pry tool over and used the short end to pry the bottom loose.
    12 - remove the alternator from the car.
    15 - insert the multispline tool from the Metalnerd kit (or 3400 tool if you have one) into the pulley
    16 - slip a 17mm wrench onto the multispline tool, and insert the M10 triple square or T50 6 lobe bit (as appropriate for your alternator) through the multispline tool. Use a 1/2 drive ratchet or breaker bar to turn the bit in a clockwise (typically tightening) direction while counterholding with the 17mm wrench. This pulley was put on to 80 Nm. The pulley will unscrew from the shaft of the alternator.
    17 - screw the replacement pulley onto the shaft, assemble the tools as above, and use a torque wrench to tighten the pulley to 80 Nm. Tightening is accomplished by turning the torque wrench counterclockwise (typically loosening) direction. Install the plastic cover.
    18 - Place a 19mm socket around the threaded inserts and press them out of the alternator mounting tab a little. The shiny surface is the side to put the socket on. I sandwiched mine in a vise to press the inserts to the position shown. This will make it easier to remount the alternator on the engine bracket.
    Installation is the reverse of removal.
    Tighten the 8mm hex bit bolt to 45 Nm.
    Tighten the alternator mounting bolts to 25 Nm.
    Tighten the 13mm nut on the large cable to 15 Nm.
  4. Re: Alternator Clutch Pulley
    Nov 2006
    I went into my local motor factors on Friday to try and order the Alternator clutch pulley, and he looked at me as if I was stupid. Basically sent me on my way suggesting I go direct to VW to purchase.
    Does anyone know of the part number and any dealers that sell this part?
    The car is a Passat 1.9TDi 85Kw (115bhp) AJM 1999
    THANKS
  5. Re: Alternator Clutch Pulley
    Hope you have better luck than me at vw i went to buy a hub bolt remover basically a 17mm allen bit and was told ''sorry mate we dont sell tools''
  6. Re: Alternator Clutch Pulley
    Nov 2006
    Yeah, I've heard that VW can be a bit awkward on that. They just want you to give up and book the car in with service team. Then you walk out later with an empty wallet.
    I've got the required tool on order from the states, cost £20 incl. shipping (BARGAIN) as some guy on E-bay is selling it for £27 + shipping.
    I've also managed to find the pulley on E-bay.com at a cost of $80 but the shipping is $97 dollars
    Hence I'm looking locally for the part. Just struggling to find anyware yet. I've tried the usual, eurocarparts, GSF etc, just hoping that someone in the forum can help.
  7. Re: Alternator Clutch Pulley
    135 Post(s)
    2039 Post(s)
    The tool is number 3400 and costs £10.95 from a VW dealer who really cannot refuse to order it; technically it is illegal to do so under Block Exemption rules. The pulley varies according to the alternator fitted but should be 022 903 119 D which costs £59.75.
  8. Re: Alternator Clutch Pulley
    Quote Originally Posted by Vingster View Post
    GSF couldnt help? They should normally stock them as this is one of the fastest movers. I think the INA number you need is 535 0005 10. If they say they don't have it, advise them to check wholesaler FPS, they definately have them, and will supply most factors.... albeit at extra cost.
    But yeah - its a relitively new thing being able to get them separate from the alternator, so many factors wont have a scooby doo yet.
    Hope that helps.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  9. Re: Alternator Clutch Pulley
    Apr 2006
    As a follow on to the ongoing issue of supplies my local VW dealer would sell me the tool needed to remove the pulley but would cost around £25.
    GMF in Llanelli sold me a Sealy SX400 kit for £17 and the pulley was £45 through Motor World in Swansea but supplied by another local motor factors (GMF I think). It's the INA pulley number 535 0005 10.
    Price through any of the VAG dealers was exaclty the same.
  10. Re: Alternator Clutch Pulley
    Aye, GMF should have been able to supply the pulley too - they are one of only a few who have a direct account with the manufacturers for these.
    2019 Urus, 2020 RS7
  1. Tool for changing Alternator Pulley Wheel
    By Scottyjohn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2008, 09:58 PM
  2. A6 1.9TDI Alternator Pulley
    By johnnywishbone in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2007, 11:46 AM
  3. Is this the Alternator pulley siezing ?
    By cbrpaul in forum Touran - Sharan - Caravelle
    Last Post: 09-08-2007, 09:43 PM
  4. Aux. belt and alternator pulley change/queries
    By dvhttn in forum Passat - Archive Topics
    Last Post: 22-03-2007, 08:29 PM
  5. 03 tdi alternator pulley
    By jeevoe999 in forum New Member Introductions
    Last Post: 26-02-2007, 12:38 AM
