Thread: 1.9 TDI/AWX - injectors lifetime
Results 1 to 10 of 10
  1. 1.9 TDI/AWX - injectors lifetime
    Dear colleagues, i'am wondering did you know what is approximately lifetime of pump-duse injectors? I have seen a commercials in mobile.de and autoscout24.de for vehicles with +350.000km with pump-duses in good and working condition. So i'm curious about the strength of this engine. I had an Audi B5 with AFN engine which was really good, and i was heard that it can run more than 500.000km without any problems. Thank you for your time!
  2. Re: 1.9 TDI/AWX - injectors lifetime
    Apr 2007
    I have heard it said that the injectors are good for about 100K miles. I did find this a bit of a surprise as I thought it would be considerably longer, bearing in mind the cost of replacement injectors. I would ike to know the life of a PD injector and whether anyone services them ?
  3. Re: 1.9 TDI/AWX - injectors lifetime
    134 Post(s)
    2009 Post(s)
    They used to fail but that seems to have stopped. These days they are very reliable.
  4. Re: 1.9 TDI/AWX - injectors lifetime
    Mine is on 150K almost and so far, it's still on the originals.
  5. Re: 1.9 TDI/AWX - injectors lifetime
    Mauritius
    I changed one on 148K, today it seems that I have to change another one on 152K.
  6. Re: 1.9 TDI/AWX - injectors lifetime
    Jul 2007
    Cheshire, or my A6
    Well all this sounds good... I'm on 52k so they've got a long way to go!
    Paul
  7. Re: 1.9 TDI/AWX - injectors lifetime
    Aug 2007
    Does vag-com tell you when they fail?
  8. Re: 1.9 TDI/AWX - injectors lifetime
    Mar 2008
    Bristol
    I actually work for a company that makes PD 'type' injectors for the large 16l truck engines, and we warrent them for 1,000,000 miles.
    i would say the bosch pd injectors should be happily lifed to 500,000km
  9. Re: 1.9 TDI/AWX - injectors lifetime
    Mauritius
    If it's a mechanical fault, it doesn't tell you, it has to be an electronic fault.
    The scan showed only Cylinder 3 misfiring
    Does anyone know that once you change an injector, the others have to be changed as they will have different amount of pressure/stress on the system which will cause them to fail as old injectors?
  10. Re: 1.9 TDI/AWX - injectors lifetime
    134 Post(s)
    2009 Post(s)
    It is OK to change one injector, the ECU will compensate for slight differences in flow, especially at idle.
  1. injectors
    By BROWN_OWL in forum Golf MK5 - 2004 - 2009
    Last Post: 24-12-2007, 05:02 PM
  2. Mk 5 2.0 TDi injectors
    By Davieboy in forum Golf MK5 - 2004 - 2009
    Last Post: 27-11-2007, 08:29 PM
  3. 2.0 FSI Injectors
    By Raiters in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-10-2007, 03:40 PM
  4. tdi injectors
    By mikeya4 in forum Audi A4 - Archive Topics
    Last Post: 05-07-2007, 11:04 PM
  5. New diesel Injectors on A4 ?
    By ad4pm in forum Audi A4 - Archive Topics
    Last Post: 09-02-2007, 09:41 PM
