Thread: Heavy Clutch
  1. Heavy Clutch
    Jan 2006
    Leigh
    My '94 Golf has had a heavy clutch now for about 2 years. The pedal seems to creak and generally makes for a noisy gear change and fierce biting point. I have got used to it over time but it's beggining to annoy me now! Could this be the cable or is it the pedal? How much would I be looking at for a new pedal assembly?
    '99 B5 Passat 1.8 T 20v Sport
  2. Re: Heavy Clutch
    134 Post(s)
    2022 Post(s)
    The clutch needs replacing.
  3. Re: Heavy Clutch
    Jan 2006
    Leigh
    Would it be simply be a replacement clutch or would I need to replace the cable aswell?
  4. Re: Heavy Clutch
    134 Post(s)
    2022 Post(s)
    We decide that after we have changed the clutch.
  5. Re: Heavy Clutch
    Jan 2006
    Leigh
    Wise words. I think it's still on it's original clutch (156K) so it's probably due to be replaced. I'm confused though, if the clutch was heavy wouldn't it be more of the cable/pedal rather than the actual clutch itself? After all, the clutch is stationary which is being moved by the pedal/cable?
  6. Re: Heavy Clutch
    134 Post(s)
    2022 Post(s)
    The pressure plate goes heavy; they have been doing this since they came out in 1974 on the Scirocco 1.5 when the 020 box was first used. You could try changing the cable first. When we change the cable we like to use what VW call the "driving school" cable which is manually adjustable rather than the auto adjust cable.
  7. Re: Heavy Clutch
    Jan 2006
    Leigh
    Ah I see. Thanks for the helpful info'! I think I might enquire about a new clutch and cable.
  1. Passat - Heavy duty clutch?
    By RobBentley in forum Passat - Archive Topics
    Last Post: 28-10-2007, 12:46 AM
  2. heavy on the juice
    By mick1 in forum Bora - 1998 - 2005
    Last Post: 17-09-2007, 06:24 AM
  3. Heavy shoulder wear!
    By Big G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-08-2007, 12:17 PM
  4. Heavy Clutch
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-08-2007, 10:22 PM
  5. How heavy is a slab
    Last Post: 12-05-2007, 02:14 PM
