Thread: water pump
Results 1 to 9 of 9
  1. water pump
    hi just booked my 130 tdi pd se passat in for a new cambelt the garage recommended i have the water pump changed as there have been alot of these going around the 70000 to 80000 miles mark my car has 48000 miles on the clock is this right they say its cheaper to do it while its getting the cambelt done could i sell the old pump on ? it still works fine
  2. Re: water pump
    Bourne End , Bucks
    Quote Originally Posted by stockportdubfan View Post
    Hi, from previous posts, it's worth changing the water pump as most the front end of the car has to be removed in order to replace it , and the same applies when replacing the cambelt. I believe the part is not very expensive anyway, the cost is in the labor time.
  3. Re: water pump
    Sep 2007
    yorkshire
    And get the one with the metal impeller, not the plastic one.
    Also if the dealers are doing the job! make sure you get a receipt for the TTY bolts used (stretch bolts).
    They do try to get away without replacing them.
  4. Re: water pump
    Nov 2006
    Definately get the water pump done.
    My cambelt was changed as per normal, car put back together, one year later, water pump goes. And as has been said earlier, you have to dismantle the front end of the car to get to it.
    When I got my water pump changed I also changed the cambelt again. The parts are cheap, its the labour in getting to it.
  5. Re: water pump
    Tyldesley, Manchester, UK
    I concur with what these above say. Mine was the other way around, the water pump failed (on warranty) and they offered (and I accepted) the cambelts which were due in another 4k for a good price
    One German, Two Italian.
  6. Re: water pump
    Aug 2007
    Quote Originally Posted by passat>sport View Post
    where are the torque to yield bolts fitted ?
    As i am thinking of doing my cam belt next week and want to order stuff ahead !
    i am looking to order.
    cam belt kit inc pullys
    water pump
    5 ltrs long life antifreeze
    power steering belt
    air con belt
    altenator belt
    4 new torx bolts for bottom pully
    Torque To Yield bolts (where ever they fitted)?
    What else have i forgot?
    shane
  7. Re: water pump
    Sep 2007
    yorkshire
    Quote Originally Posted by BICCUS1 View Post
    water pump
    power steering belt
    air con belt
    altenator belt
    shane
    Tensioner stud, Is yours a passat PD btw. There is a picture on the front of the cam belt cover showing you the nm's and tightening degrees.
    Have you got the crankshaft locking tool also?
    I can mail you instructions if you PM me your engine code and E-mail address.
    2003 AUDI AVANT SPORT TDI
  8. Re: water pump
    Aug 2007
    Sorry for long delay never got round to doing the job but will do this week as off work !!
    Called the dealer today and they want to know where the Torque To Yield bolts are fitted and also why i want new bolts for bottom pully as they don't normally sell them !!
    My e-mail is biccus1@aol.com and engine code is AVF
    Thanks shane
  9. Re: water pump
    Sep 2007
    yorkshire
    Hi Sorry for long delay never got round to doing the job but will do this week as off work !!
    Thanks shane
    It's the stud bolt that holds the t/belt tensioner in place, I dare say some people re-use them but if it comes loose......
    Pulley bolts are made from a copper/brass type metal with an allen key slot, I always manage to round a couple (easy to do with the soft metal) I normally just replace these with some normal bolts.
    Search for a guy called "CRASHER" on here, he does this stuff everyday and is very helpful, I'm sure he will have some better tips than I can give with regard to the bolts!
    If you need help though on how to do the belt, let me know and i'll talk you through it.
  1. After run water pump
    By mpboniface in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 13-07-2007, 11:59 PM
  2. Water pump symbol?????
    By Johneavsnflat5 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 04-05-2007, 10:57 AM
  3. water pump
    By garying3980 in forum Passat - Archive Topics
    Last Post: 27-02-2007, 06:34 PM
  4. Water pump..noise ???
    By redmax90 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-01-2007, 04:06 PM
