Thread: Protective rubber strips at bottoms of doors
Results 1 to 10 of 20
  1. Protective rubber strips at bottoms of doors
    Dec 2006
    Hi, Have an S Reg A4 and the Protective rubber strips at bottoms of doors that are held on by mild steel clips have rust badly are disintegrating and I have already lost one. SOme of the clips have gone and some of the groove on the strip has disintergrated as well. Does anyone know how to reattach them? Many Thanks Lenny
  2. Re: Protective rubber strips at bottoms of doors
    134 Post(s)
    2022 Post(s)
    The plastic clip is held onto the door by a little metal stud and I have never seen one of those studs fail. The normal solution is a new set of clips and rubber strip.
  3. Re: Protective rubber strips at bottoms of doors
    Dec 2006
    Thanks Crasher, so a new set of clips then from Audi. Are the old ones difficult to remove?
  4. Re: Protective rubber strips at bottoms of doors
    134 Post(s)
    2022 Post(s)
    Once the strip is off (don’t forget the self taper at the front of the front door trim, accessed from inside and below the lower hinge) and the clips just open up and come off. They are part number 8D0 853 909 B and cost £0.51 each.
  5. Re: Protective rubber strips at bottoms of doors
    Dec 2006
    Thanks Crasher (again), I'm happy with the clips TVM, but if the strip has corroded where the clips clip in, would it mean a new strip? I bet that Audi dont do them anymore. Lenny
  6. Re: Protective rubber strips at bottoms of doors
    134 Post(s)
    2022 Post(s)
    The strip is still available.
  7. Re: Protective rubber strips at bottoms of doors
    Dec 2006
    Thanks mate. I will ask Audi how much and go from there. Thanks once again. Lenny
  8. Re: Protective rubber strips at bottoms of doors
    Mar 2007
    vagparts do a full set of four trims for £50.
  9. Re: Protective rubber strips at bottoms of doors
    Dec 2006
    Quote Originally Posted by darkhorse1001 View Post
    Thanks mate. Do Vagparts have a website?
  10. Re: Protective rubber strips at bottoms of doors
    Mar 2007
    https://sslrelay.com/s74326199.onean...dex.shopscript
    go to product overiew, audi, A4 B5, exterior, lower door trims....
    had a set on mine for a year now and all rubber is as good as new and fixings are all still nice and firm, made the car look about five years younger than it did with the old ones half on half off...
  1. Rubber sensing pipes
    By happysnappy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-10-2007, 10:20 PM
  2. Side strips on a MK4 Golf
    By crazylegs in forum New Member Introductions
    Last Post: 11-10-2007, 04:48 PM
  3. Cambelt and 'rubber runner'
    By gingerneil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2007, 04:13 PM
  4. Rub Strips
    By Andyrg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2007, 09:10 PM
  5. 98 passat door strips.
    By Danozeman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-05-2007, 05:25 PM
