Thread: In car heater not working.......
  1. In car heater not working.......
    Hi everyone, I'm a new member so hello. I'm looking for some advice on a problem with my Golf. It's a 1.6 CL petrol 5door 1995 model.
    The in car heater recently stopped blowing hot air when on (only blows cold) and the car overheated. The RAC said it was the thermostat, so I replaced the thermostat, but this still hasn't solved the problem.
    The outlet pipes from the radiator are getting hot as expected, the fan kicks in when required, the matrix pipes are getting hot as expected, but the car is still overheating and blowing cold air through the fan.
    I'm at a loss - any suggestions greatly appreciated.
    Thanks in advance.
  2. Re: In car heater not working.......
    Cheshire
    Sounds like it may either have a air lock in the system or possibly your head gasket has gone ?
    1/ are both the top and bottom radiator hoses and/or the top and bottom of the radiator getting hot ?
    2/ are both the heater hoses getting hot ?
    3/ have you tried back flushing the system out ?
    4/ is there water circulation ?
  3. Re: In car heater not working.......
    Thanks for your reply Kev3dr,
    Yes, they are both hot.
    Yes, tried that.
    As far as I can tell, but someone mentioned an 'impellar' in the water pump which may have busted.
    I've garaged the dam thing now as am fed up with spending time in this cold weather under the bonnet, so hopefully a resolution will be forthcomming!! (jess kisses his teeth and says........'Gonna cost ya mate'.
    Thanks for the advice though. All the best. J.
  4. Re: In car heater not working.......
    134 Post(s)
    1994 Post(s)
    These breakdown people can be muppets, the thermostats control is outside of the heater circuit, it prevents water flow to the radiator not to the heater matrix. That symptom is classic water pump impeller failure. If it wasn't overheating I would say it was a blocked heater matrix and head gasket failure is still possible but I would do the water pump first. The water pump is driven off the cam belt on the 95 1.6.
  5. Re: In car heater not working.......
    Maybe the gasket has gone, I think it also
    Can I ask you something: 10 minutes after you start the car if you try to squeeze the top and bottom radiator hoses are they hard as a stone? If it it so you have air in the cooling system.
    How often do you pour liquid in the cooling system? I mean does the liquid from the cooling system "dissappear" without any visible blead or leak from the cooling system?
    First when you start your motor with open pessure cap of the cooling system and keep 2500 rpm and look into the cooling vessel do you see bubles?
  6. Re: In car heater not working.......
    If the termostat is defected in open state then you won't have overheating, but if the termostat is defected in close state you will have overheating and you will have good heating in the car
    When I had such problems with my Opel I made the following: The engine was cold. I removed cooling system pressure cap and started the motor for a couple of minutes untill the temperature is still below 80 celsius degrees. And beleive I HAD HEATING in this case!!!
    But it could be water pump - less capacityр but it's less possible
  1. Auxiliary Heater not working
    By rikwalter in forum Alhambra
    Last Post: 30-12-2007, 11:45 PM
  2. Golf Mk II heater not working
    By Paul L in forum Golf MK2 - 1984 - 1992
    Last Post: 28-12-2007, 06:36 PM
  3. VW Polo heater not working ???
    By clarkyWRX in forum Polo - Derby - Lupo - Fox
    Last Post: 13-12-2007, 05:00 PM
  4. Heater not working '90
    By MCMark in forum Early Passat Forum - Pre 97
    Last Post: 17-11-2007, 11:06 AM
  5. 96 passat heater fan not working
    By macerena in forum Passat - Archive Topics
    Last Post: 08-03-2007, 07:49 PM
