Thread: Loose Gearbox
  1. Loose Gearbox
    Oct 2006
    Hi I own a Mk2 Golf 89.
    The gear box is so loose that it will go into reverse without pushing down. This is a particular problem for my girlfriend as she is a new driver. I have a Haines manual and have looked to see if this is an easy fix. I think it might just be aspring but am unsure - can anyone shed any light on this problem?
    CHeers
    James
    There is a spring that needs to be compressed to get reverse. If you lift the gaiter up from around the gear lever I think you can see it. I had to change it on my MK II GTI. It was a long time ago and I am struggling to remember (old age!). I brought a kit with bushes & springs from a local VW specialist. It was a bit fiddly and I needed a hand to hold the gear lever in place whilist I tightened the clamps up in the engine bay. Sorry I can't be more helpful like I said it was a while ago.
    Regards Boardboy.
  3. Cheers
    Oct 2006
    Great that doesn't sound too hard!
    So all this can be done from the cab and I don't need to ramp it for any reason?
    Regards
    You can withdraw the gear lever from inside the car. I should have mentioned make a witness mark on any of the linkages that you disturbe, so you have got an idea of where they were.
    Good Luck
    Boardboy.
    I have just sold my Golf and whilist going through all the old receipts I have found the one for the gear lever repair kit. It was from a VW specialist but but it has a VAG referance number if this is any help.
    191 798 116 Gear Lever Repair Kit.
    171 798 211 Bush kit Gear Lever.
    Regards Boardboy
  1. Loose Door Handle
    By Piez in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2016, 05:12 PM
  2. Bora - Loose Air con unit?
    By Jugga in forum Bora - 1998 - 2005
    Last Post: 26-06-2007, 12:02 AM
  3. Loose wire
    By Cara2007 in forum Archive posts
    Last Post: 27-04-2007, 11:23 PM
  4. Gearbox ECU
    By doordoctor in forum Archive posts
    Last Post: 05-10-2006, 07:49 PM
