Thread: Liquid dripping onto pedals 2000 (W) Polo
  1. Liquid dripping onto pedals 2000 (W) Polo
    Jan 2008
    Hi all,
    First post here for me: my mum's 2000 W reg Polo 1.4E has started dripping liquid (probably water) onto the brake and accellerator pedals. The carpets and mats get very wet.
    Anyone got any ideas on where to start looking? Having done a quick search here on the forum I am thinking of windscreen seal, bulkhead seal or pollen filter. Not sure where the pollen filter is. Also thinking about about heater cores/matrices etc as they can leak on SAABs (which is what I drive, along with a 1970 Beetle .
    Not having the car at hand or the Haynes manual I am looking for suggestions before diving into the car to effect a speedy repair and keeping my Mum happy!
    Cheers,
    Fraser
  2. Re: Liquid dripping onto pedals 2000 (W) Polo
    Are you sure that is where the water is coming from,our 2000 polo had wet carpets on drivers side,turned out to be the door drains which were blocked & rain water from inside the door was finding it's way over the seal & on to the carpet
  3. Re: Liquid dripping onto pedals 2000 (W) Polo
    Jan 2008
    I'll bear that in mind, but given that the pedals are wet, I suspect it isn't coming in the doors..... More from under the dash somewhere....
  4. Re: Liquid dripping onto pedals 2000 (W) Polo
    I had the same problem which I traced back to the "gutter" along the windscreen, under the grill. Leaves had dropped in and blocked the weep hole that takes water out over the front wheel.
    A piece of straightened wire hanger and a strong hose pipe spray did the job.
  5. Re: Liquid dripping onto pedals 2000 (W) Polo
    Jan 2008
    That sounds like my kind of fix! I only got the car for her last month and when checking it over noticed a number of leaves at the back of the engine bay: I'll certainly be inspecting that area next weekend!
    Many thanks,
    Fraser
  6. Re: Liquid dripping onto pedals 2000 (W) Polo
    Don't stop at clearing the leaves. They rot into a mulch whcih actually block the draining tube. Run a hose through the drainage tube to make sure it's clear.
    Do the passanger side as well.
  7. Re: Liquid dripping onto pedals 2000 (W) Polo
    Jan 2008
    Oh...I will! Oh yes.
  1. 2000 Polo - x Reg - Help please?
    By mellowmunkee in forum Polo - Derby - Lupo - Fox
    Last Post: 03-01-2008, 07:08 PM
  2. noisy gearbox 2000 polo gti
    By paresh1uk in forum Polo - Derby - Lupo - Fox
    Last Post: 20-12-2007, 06:36 PM
  3. Sports pedals for an Automatic
    By toff in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-09-2007, 11:10 PM
  4. 2000 Polo GTi Oil
    By bryn_p in forum Polo - Derby - Lupo - Fox
    Last Post: 08-04-2007, 09:11 PM
  5. Trouble With 2000 Polo
    By Hooch in forum Polo - Derby - Lupo - Fox
    Last Post: 02-01-2007, 10:10 AM
