Thread: Audi 100 heater matrix and wheel wobble
  1. Audi 100 heater matrix and wheel wobble
    Jun 2009
    Skelmersdale, England
    I suspect the heater matrix on my '91 100 is on the way out but I thought I would check other opinions before I start the pig of a job. Sometimes when driving the bottom of the windscreen starts to mist up and when the fan is turned on it gets worse before it clears. The engine does not use any water but I suspect the matrix has a slight weep and is causing a bit of steam to rise up.
    I also have a slight intermittent wobble from the front when cruising at motorway speeds but the wobble is felt through the throttle pedal rather than the steering wheel so I dont suspect wheel balance. Could it be a worn inner or outer cv joint?
  2. Re: Audi 100 heater matrix and wheel wobble
    Mid Cheshire
    Is there any smell with the blower on when it is set to hot? I've had the heater matrix go on a Mk2 Golf and Audi Coupe and when set to hot they misted up the windscreen and released a smell.
    "If a donkey bray at you, don't bray at him."
  3. Re: Audi 100 heater matrix and wheel wobble
    Jun 2009
    I know what you mean about a smell that normally accompanies the misting but I cant smell anything yet.
  4. Re: Audi 100 heater matrix and wheel wobble
    Dec 2007
    8 Post(s)
    Quote Originally Posted by FCB View Post
    Check to see if your model has a pollen filter.If it was clogged up it could cause
    misting problems. Some Audi 80s have them fitted under a plastic tray in front of windscreen lhs
  5. Re: Audi 100 heater matrix and wheel wobble
    Oct 2009
    north of england
    If it clears quickly maybe you could could live with it for a while yet, if the antifreeze smell is there and never clears. then replace. Once had a matrix explode in a traffic jam.
  1. newbie- mk1 golf gti stripping to build a new baby
    By grungeisdead in forum New Member Introductions
    Last Post: 24-02-2008, 09:46 PM
  2. Heater core replacement 93 passat VR6
    By farmhemi in forum Passat - Archive Topics
    Last Post: 05-01-2008, 04:25 AM
  3. golf mk3 1996 19d heater radiator. any help pls!!!!
    By jazone in forum Golf MK3 - 1993 - 1999
    Last Post: 24-09-2007, 02:11 PM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
