Thread: replacing battery in key fob
  1. Question replacing battery in key fob
    Ballygally, N. Ireland
    In one of my remote controls I need to go very close to the car before the remote works so I assume this is because the battery is nearly flat. 2001 A4.
    What I was wondering was if I replace the battery do I then then need it reprogrammed and does this mean taking it to the dealer?
    Dave
  2. Re: replacing battery in key fob
    Quote Originally Posted by dancerdave View Post
    Dave
    replacement of the battery may required a re-sync to the central locking, but as far as the immobiliser is concerned, you will not have a problem
    re-syncing is easily done via vagcom or a manual method well documented on the forum.
  3. Re: replacing battery in key fob
    just changed the battery and didn't need to re-synch anything
    but the remote still doesn't work very far away
  4. Re: replacing battery in key fob
    Dec 2007
    www.uk-mobilestore.co.uk
    can som1 please help me i am having the same problem i bought an battery from tesco and changed it, now i have to go very very close to the car then only it will unlcock the car
    please som1 please help me on how i can slove thhis problem
  1. Replacing gaiter
    By jazzzza in forum 80 - 90
    Last Post: 05-11-2007, 07:22 PM
  2. replacing the KKK with a Garrett
    By biglockie in forum Archive posts
    Last Post: 31-10-2007, 04:20 PM
  3. replacing the turbo on TDi 110
    By teedeeAye in forum Golf MK4 - 1999 - 2004
    Last Post: 26-09-2007, 05:15 PM
  4. Replacing tdi engine
    By joesantos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2007, 11:03 PM
  5. replacing clutch on tdi
    By glynnd in forum Passat - Archive Topics
    Last Post: 07-09-2006, 04:21 PM
