Thread: Rust beneath battery - K reg Polo
Results 1 to 10 of 13
  1. Rust beneath battery - K reg Polo
    bingo23 Guest
    Hello All
    I recently bought a polo that seemed in quite good nick till I got a wet foot while driving in the rain, and had a look under the battery
    and found a big rusty hole
    I've cleaned away the rust , and painted with hammerite, and then covered the hole with a plastic lining to keep my feet dry, but does anyone know whether this might cause it to fail its MOT? which is due in February?
    Any advice greatly received, thanks
  2. Re: Rust beneath battery - K reg Polo
    Oct 2007
    Hi With the battery in place they will not be able to see the hole
  3. Re: Rust beneath battery - K reg Polo
    bingo23 Guest
    Thanks Kenny,
    the Hammerite was white (it was all i had) and can be seen around the battery as can the plastic sheet - would they not investigate if the tester was being thorough?
    I don't think the rusted area is structural - there is a much thicker and sound/unrusted piece of metal to the right of the hole that I'm guessing is part of the sub frame.
    thanks very much for your help
  4. Re: Rust beneath battery - K reg Polo
    Canada
    get a plate welded in there, it shouldn't cost allot (no expensive spraying) as you cant see it and then you know your safe and dry
    I Suspect that battery acid has corroded the paint and let the rust get hold.
  5. Re: Rust beneath battery - K reg Polo
    bingo23 Guest
    thanks onzarbob.
    Any idea how much getting a plate welded will cost me?
    As I only paid 275 for the car and I'd rather not throw money at it.
    I have put piece of aluminium sheet that was lying around under the battery for extra strength but its only secured by the weight of the battery.
    thanks again
  6. Re: Rust beneath battery - K reg Polo
    131 Post(s)
    1979 Post(s)
    It is evil work to do properly; there are quite a lot of things to catch fire around there. I have done so many of these over the years I have lost count but to have it done properly and to replace the broken battery retaining bolt (I am guessing it is broken but they usually are) will cost more than you paid for the car. Running a Polo like that can't be based on the practice of no repairs costing more than what you paid for it, it won't last long running it like that.
  1. Battery
    By rtdc in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-12-2007, 08:24 PM
  2. Should my 2 year old a4 have rust bubbling on the bootlid??
    By glynburrtwo in forum Audi A4 - Archive Topics
    Last Post: 27-09-2007, 10:01 PM
  3. Polo draining battery
    By derbyaj in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2007, 04:02 PM
  4. RUST Rear window pillow ( pictures )
    By redtony in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-05-2007, 04:13 PM
  5. POLO KEY FOB BATTERY
    By newshawk in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2006, 09:03 PM
