Thread: Touran battery drain
Results 1 to 8 of 8
  1. Touran battery drain
    Dec 2007
    Hi All
    Anyone have experience of VW Tourans that drain their batteries? The battery is fine, but when the car is left for even 12 hours the battery is flat.
    It jumpstarts ok. Any ideas?? Thanks in advance. I have a 53 reg 2.0 TDI Sport.
  2. Re: Touran battery drain
    Mar 2007
    did you ever find out? I have exactly the same problem with exactly the same car! thought it was the hands free kit but now I'm thinking it may be the central locking...
  3. Re: Touran battery drain
    Jan 2009
    towcester northants
    several issues
    1 the door ecus
    2 the central elecrics box by battery gets water ingress
    get diag test done then isolate by removing fuses 1by1 with ammeter connected to isolate circuit
  4. Re: Touran battery drain
    Mar 2007
    thank you. Did the fuse test, both central (which was ok) and the one under the steering wheel, and fuse 49 - central locking was drawing 0.37Amps (think I got that right!) not sure where to go now other than shell out a vw garage to sort it out. could it be the central locking pump? I replaced the tailgate microswitch about a year ago, but doubt that's relevant.... cheers
  5. Re: Touran battery drain
    Dec 2007
    Quote Originally Posted by SJH View Post
    Thanks.
    I still have no idea. My airbag has a persistent warning light. It could be that. I need to do the ammeter and sequential fuse removal tactic. What makes you think its the central locking?
  6. Re: Touran battery drain
    Jan 2009
    towcester northants
    ive change several door ecus for battery drain on tourans and mk5 golfs
    ive also changed the electrics box by battery due to corrosion
  7. Re: Touran battery drain
    Dec 2007
    Thanks will try and look at the Touran's door ECUs.
  8. Re: Touran battery drain
    Aug 2009
    Stratford-upon-Avon
    I know there where issue with the radio's draining the battery.You can try disconnecting it and checking the battery draw.It may take a couple of hours for everything to shut down so you get an accurate reading!Also with the radio or any component disconnected you may get a draw which will be the ecu 'searching' for the disconnected component!Its worth trying anyway!
  1. battery drain
    By jasey1007 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2008, 08:29 PM
  2. passat tdi battery drain
    By andycampers in forum Passat - Archive Topics
    Last Post: 18-11-2007, 04:37 PM
  3. battery drain plug
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2007, 10:00 AM
  4. Battery drain
    By nickasaki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2006, 01:51 PM
  5. Passat Battery drain
    By Blobnose in forum Passat - Archive Topics
    Last Post: 20-09-2006, 05:44 PM
