Thread: A4 service reminder
  1. A4 service reminder
    Jan 2008
    Hi.
    I have a 1999 A4 tdi and have tried all the options in the Haynes to remove the service reminder to no avail ie. press button A switch ign on release button A and then pull button B for two secs and that should work but it doesn't.
    Any ideas please
  2. Re: A4 service reminder
    Oct 2007
    Hi–Switch off ignition.Press the reset button for the trip recorder on the dash panel insert and at the same time switch on the ignition.The display of trip recorder shows: “serviceOIL”.Release the button.Pull out clock adjuster knob for approx. 2 seconds to reset “serviceOIL”.Depending on manufacturer of dash panel insert the trip recorder display will either continue to show “serviceOIL” (Nippon Seiki) or it will display “- - -” (VDO).Press the reset button for the trip recorder again to call up the next type of service.Release the button.The display of trip recorder shows: “serviceINSP”.Pull out clock adjuster knob for approx. 2 seconds to reset “serviceINSP”.Switch off ignition.
  3. Re: A4 service reminder
    Jan 2008
    Thank you Kenny and why don't the books tell you this as there is no mention of pressing the reset button at the end.
  1. Re-map/Service/Vag-com
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-11-2007, 05:31 PM
  2. Does resetting service indicator set service regime to fixed?
    By golfgtdude in forum Golf MK5 - 2004 - 2009
    Last Post: 01-10-2007, 06:38 PM
  3. service reminder reset
    By NIgolf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-07-2007, 09:05 AM
  4. A3 service
    By dumpee in forum Audi A3 - Archive Topics
    Last Post: 23-04-2007, 05:25 PM
  5. Service now
    By phils2309 in forum Passat - Archive Topics
    Last Post: 01-12-2006, 03:05 AM
