Thread: Unlock (NOT )
  1. Question Unlock (NOT )
    Dec 2007
    I have an Octavia 1.9TDi Est Elegance ( 51 Plate ). The problem I have is with the central locking, It was Fine on Saturday eveneing when I locked it and then on Sunday when going out I Pressed the ulock button on the fob, it makes the noise and the drivers side button pops up and then the car locks itself again. I then try to unlock it again it makes the noise but the button does not popup. I then lock the door and then press the lock button on the fob again, then I have to press the open button and open the door quick. Also If the engine is running and I press the button on the door console to lock all doors the doors lock fine, if I then press the open button the doors unlock and then lock again. Very strange, If anyone can help,
    best regards
    AVAGO
    PS:HAPPY NEWYEAR TO YOU ALL
  2. Re: Unlock (NOT )
    Nottingham
    Sounds like a mechanical issue in the door, bit like if you unlock and are trying to open the door at the same time. Of course a fault code scan should also be done, just in case there is a fault detected.
  1. Golf Mk4 rear door won't unlock
    By CrossMouse in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2020, 12:34 PM
  2. Doors unlock but dont open?
    By m4xmw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2008, 12:43 AM
  3. All Doors Wont Unlock
    By elmoreno1785 in forum Passat - Archive Topics
    Last Post: 05-05-2007, 11:06 AM
  4. passenger door will not unlock
    By photogr22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-04-2007, 10:52 PM
  5. Unlock the boot and the windows open?!
    By The Stagg in forum Passat - Archive Topics
    Last Post: 06-01-2007, 11:55 PM
