Thread: ck3100
  1. ck3100
    Dec 2007
    I saw that on the vwaudi forum you are familiar with parrot kits. I have a ck3100 and I am looking to install it in a vw golf.
    Do I have to use the leads that came with the parrot and a harness? aswell ifso how do I wire up the leads to get power to the parrot?
    With a golf I am aware that I will have to find a permanent live from either the cig lighter or fuse box however, which wires do I use? the harness or the parrot cable with inline fuses?
    Any help would be appreciated
  2. Re: ck3100
    A, A
    Just another B7 Estate
  3. Re: ck3100
    Dec 2007
    Thankyou very much, that came in very handy many thanks
  4. Re: ck3100
    Nr Falkirk
    Have you done this I struggled to find a switched live as they all seem to be permanent
    Ta Des
  5. Re: ck3100
    Up North
    Quote Originally Posted by descb600f View Post
    Open up the fuse box inside the drivers door and get cracking with a multimeter. You just need to find an empty fuse position which is live with the ignition on and dead with it off.
    I can't tell you which one, because they seem to vary from model to model (I've done 3 cars like this).
    Then use a spade connector crimped on the end of a cable, stuck into that position. Make sure you use an in-line fuse in the cable, to protect the electrics .
    Presto!
    The other option is to use a scotchlok connector on the supply to the 12V socket in the ashtray.
  6. Re: ck3100
    Sep 2007
    I'm interested but I can't help feeling that having the parrot unit stuck to the dashboard is an open invitation to the thieving scum that walks the streets to break in and take it.
    Or is it removable?
  1. Parrot CK3100 Connecting
    By echoman1979 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-07-2010, 05:43 PM
  2. parrot ck3100 which lead?
    By verachion in forum Golf MK5 - 2004 - 2009
    Last Post: 29-12-2007, 07:56 PM
  3. Ignition feed for Parrot CK3100
    By smithian in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-09-2007, 02:30 PM
