Thread: Bora Clutch Raised High
  1. Bora Clutch Pedal Raised High
    Dec 2007
    I recently had to replace the white plastic clip and pedal switch clip on the clutch of my VW Bora 2L Sport X reg after these snapped off whilst travelling. Since the replacement, the clutch pedal is raised higher than the brake pedal with no means of adjustment. I noticed that the housing/metal plate that the clutch pedal rests against has a hole which suggests space for a "stopper" that the clutch pedal could rest against thus keeping it level with the brake pedal. Is this correct and if so, does anyone know the part required? Alternatively please advise if there is a means of adjusting.
    jidejemiyo
  2. Re: Bora Clutch Pedal Raised High
    Hi I think you need to have a look were the master cylinder operating rod fits into the pedal i fancy this is not located properly,hence the high pedal.
  3. Re: Bora Clutch Raised High
    Kings Lynn
    The little white clip you put in has a small round resess for the ball of the piston rod. If the ball is not sat in this the pedal will be raised. I have just had the same happen to me!
  4. Re: Bora Clutch Raised High
    135 Post(s)
    2026 Post(s)
    Is the little box section in the pedal (where the white plastic box clip slides into) open at the back?
  5. Re: Bora Clutch Pedal Raised High
    Dec 2007
    I refitted the plastic white clip again and this time the pedal is level. Thanks for your help
  6. Re: Bora Clutch Raised High
    Dec 2007
  1. High Clutch Pedal
    By Jabez in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2010, 03:26 AM
  2. A4 Avant 1.9TDI High Clutch Bite Point
    By jackreacher in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-11-2007, 09:03 AM
  3. High Clutch
    By gazaaa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-11-2007, 02:22 PM
  4. Bora Aircon Switches Off On High
    By sandhamm in forum Bora - 1998 - 2005
    Last Post: 13-05-2007, 12:36 AM
  5. CLUTCH BITING POINT TOO HIGH
    By shabs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-04-2007, 07:29 AM
