Thread: 1997 1.8 T Sport: WIND NOISE
  1. 1997 1.8 T Sport: WIND NOISE
    Mar 2007
    Fife
    I'm getting really bad wind noise around the passnger front door area at upwards of 65mph. What could be causing this and does anyone have any tips for reducing wind noise? Are new door seals the answer?
    A4Chris
    1997 Audi A4 1.8T Sport
  2. Re: 1997 1.8 T Sport: WIND NOISE
    Mar 2007
    Have you checked that the window is tightly closed? It only needs to be very slightly open to create a lot of noise.
  3. Re: 1997 1.8 T Sport: WIND NOISE
    134 Post(s)
    2019 Post(s)
    Bad frame alignment, common after a window has been replaced. Check the make of glass in that door to the rest to see if it is different.
  4. Re: 1997 1.8 T Sport: WIND NOISE
    had the same problem on my 96 top of the door frame my be out of alinement all had to do was push the frame back with a careful hand
  5. Re: 1997 1.8 T Sport: WIND NOISE
    Jul 2006
    Thought i'd continue this thread than start anew one having read the replies.
    Anyway, noticed a similar wind noise from the passenger side door at motorway speeds. How do you adjust the frame as mentioned in the earlier post? Is it a case of pushing it towards the car or upwards?
    Any help greatly appreciated.
  6. Re: 1997 1.8 T Sport: WIND NOISE
    push frame towards the car
  7. Re: 1997 1.8 T Sport: WIND NOISE
    Jul 2006
    Thanks! did the trick
  1. a4 turbo sport 1997 problems
    By yeti67 in forum Archive posts
    Last Post: 20-11-2007, 12:09 AM
  2. 1997 TDI Sport Questions
    By robfoskett in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-07-2007, 10:50 AM
  3. Humming/Wind down? Noise When turn off Ignition -
    By BrendanDoyle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2007, 05:10 PM
  4. Golf MK5 Door wind noise and rattles
    By tony444 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-05-2007, 03:28 PM
  5. Wind Noise Problem A3 1998 1.8 20V
    By PARMARZ in forum Audi A3 - Archive Topics
    Last Post: 27-02-2007, 11:40 PM
