Thread: OBDII Socket on 2.5 V6 Tdi
  1. OBDII Socket on 2.5 V6 Tdi
    Dec 2007
    I have a Y2000 Passat 2.5 V6 Tdi, does anyone know where the OBDII socket is located on this model?
    Thanks, Steve
  2. Re: OBDII Socket on 2.5 V6 Tdi
    Jun 2006
    UK, Mids
    Under the steering wheel/above the pedals or in the centre console cubby hole.
  3. Re: OBDII Socket on 2.5 V6 Tdi
    Dec 2007
    OK, thanks I'll take a closer look. I did scope out those area's but could not see the socket.. must be behind the trim. Wanted to check before I started removing trim etc..
  4. Re: OBDII Socket on 2.5 V6 Tdi
    Jun 2007
    Central Scotland
    I think you'll find the OBD port on your B5.5 under the dash above the brake pedal.
  5. Re: OBDII Socket on 2.5 V6 Tdi
    Dec 2007
    OK, thanks. Found it now. On the 2.5 V6 Tdi model it's in the center consol under the handbrake, below the rubber coin holder..
  6. Re: OBDII Socket on 2.5 V6 Tdi
    Jun 2006
    UK, Mids
    Yes it changed in 2000 (the year of your car), that's why I gave both possible locations.
  1. Why do these OBDII / DTC Fault codes keep coming back ?
    Last Post: 30-11-2007, 07:01 PM
  2. Diagnostic Socket - Where is it??
    By marleyp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-06-2007, 10:04 PM
  3. OBDII and the PASSAT 1.8 engine
    By jfdale in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 12:36 PM
  4. 12v socket?
    By frank99jc in forum Passat - Archive Topics
    Last Post: 19-11-2006, 01:08 PM
  5. OBDII connector in Passat 2003...
    By anoak in forum Passat - Archive Topics
    Last Post: 09-07-2006, 07:36 PM
