Thread: Front brake pads Passat diesel estate 2002
  1. Front brake pads Passat diesel estate 2002
    allencook Guest
    Over the Xmas period with all local garages closed the warning light for front brake pad wear came on. I duly acquired the appropriate set of pads as I decided to change them myself-a job that I have done numerous times before on other carsn (Omega, Carlton, Montego, Maestro etc.) Using the Haynes manual as ag uide I took the first wheel off, removed the pad locating spring and the tried to unfastem the warning light wire. The manual told me to lift the clip on top and then turn through 90 degrees. On top of this connection is a small channel sheped piece of metal with what looks like a small tab sticking up through a small hole at the back end. Nothing relating to this channel piece seems to move. Am I missing something or is this a different fitting to what is referred to in the Haynes manul. Advice will be much appreciated.
    Thanks,
    Allen
  2. Re: Front brake pads Passat diesel estate 2002
    Oct 2007
    Hi if you take a look at the connector on your new set of pads it will give you an idea how the two parts are connected.You do not have to turn them 90 degrees.They can be a bugger to get apart,clean and spray them, before you start pulling, and should you be unfortunate and destroy the connector,then you will just have to join the wires,otherwise you will have to replace the wiring loom.
  3. Re: Front brake pads Passat diesel estate 2002
    the 90 degree twist is to release the plug body from it's mounting. Getting the plug apart is sometimes easier if you push it hard together first, and clean the dirt from release/retaining clip, but kenney is right, they can be an absolute bugger.
  1. Front brake disks/pads need replacing.
    By bob-lad in forum A8 - S8 - V8
    Last Post: 15-02-2010, 02:46 PM
  2. VW Polo Front brake pads - Advice Please
    By liuc in forum Chat - Anything with wheels
    Last Post: 20-10-2007, 02:22 PM
  3. A4 Front Brake Pads
    By mrp727 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2007, 06:42 PM
  4. Front brake pads that never wear out!!
    By Matt B in forum Chat - Anything with wheels
    Last Post: 29-03-2007, 03:12 PM
  5. Fitting front Passat brake pads
    By ansumstan in forum Passat - Archive Topics
    Last Post: 04-12-2006, 12:30 AM
