Thread: How to change water pump belt
Results 1 to 9 of 9
  1. Question How to change water pump belt
    Dec 2007
    I need to change the alternator and water pump belts on a mk III 1.9 non turbo diesel.
    I can see how the alternator belt loosens but I cant figure out how to slacken the water pump v belt.
    I,ve had a look underneat and slackened a 13mm bolt with a strange washer type thing behind it - this is right at the bottom of the engine near the water pump but I cant get anything to move.
    Any help would be appreciated - many thanks
    Mark
  2. Re: How to change water pump belt
    134 Post(s)
    2009 Post(s)
    What is the year and engine code?
  3. Re: How to change water pump belt
    Dec 2007
    The year is 1994 and engine code is 1Y382129.
    Thank you
  4. Re: How to change water pump belt
    134 Post(s)
    2009 Post(s)
    I thought that sounded odd last night but I have to admit to not being at my best at the moment, I have a serious case of Man Flu. The pump driven from the V belt is the power steering pump. The diagram should help, release bolt 1 and nut 2 and lever the alternator down, I use a crow bar. The power steering pump is released by undoing the bolts and moving the adjuster
  5. Re: How to change water pump belt
    Dec 2007
    Many thanks for this - I did manage to slacken the alternator and lever it down but I couldn't get any movement on the power steering pump when I loosened the bolt on the bottom - I'll give it another go - Thanks again
  6. Re: How to change water pump belt
    Dec 2007
    I can get the alternator belt off ok ( well off the pulleys anyway - the bottom belt needs to come off to remove it completely ) , trouble is I can't figure out how many bolts to undo to get some movement on the water pump belt - I slackened a 13mm right at the bottom then a 16mm a little higher up nearer the front - still no movement.
    thanks again
  7. Re: How to change water pump belt
    Dec 2007
    Sorry - I keep calling it a water pump belt - it's actually power steering
  8. Re: How to change water pump belt
    May 2009
    Brighton
    So how did you eventually take the alternator belt off?
    I have the same problem - I can easily slacken the alternator belt, but I can't get the power steering belt to slacken off, so that I can get the alternator belt off completely and put a new one on.
  9. Re: How to change water pump belt
    Dec 2007
    Someone did the job for me - when I watched them they slackened the power steering belt from underneath just behind the drivers front wheel - they jacked the car up to get at it - there is a bolt there that needs to be undone - I think there is a panel that you may have to remove - sorry I cant be any more help.
  1. £300 for timing belt and water pump ??
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 07-09-2007, 05:15 PM
  2. Timing belt, water pump, MAF - MK4 GTi
    Last Post: 29-08-2007, 03:02 PM
  3. Golf 115BHP PD Cam belt/water pump
    By davey_boy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-08-2007, 01:54 PM
  4. Cam belt/water pump fault
    By buyasaab in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2007, 12:18 AM
  5. After cambelt and water pump change
    By shazzies in forum TT - 8N Forum - 1998 - 2006
    Last Post: 02-02-2007, 07:24 PM
