Thread: Central locking and courtesy lights
  1. Central locking and courtesy lights
    The central locking pump and courtesy lights on my 1993 audi 80 2.8E Quattro recently stopped working at exactly the same time. The lights work if you switch them on manually. but not off any of the doors. Central locking stopped working completely, no sound from the pump. I am guessing the 2 faults are linked. Can anybody suggest where I should start looking? Thanks in advance.
  2. Re: Central locking and courtesy lights
    Quote Originally Posted by barryw View Post
    You will need a wiring diagram to check the feeds and earths to the pump.If there ok chances are its the pump.Also check fuse box for fuse protecting locking.
  3. Re: Central locking and courtesy lights
    Quote Originally Posted by ur 811 View Post
    So are the courtesy lights linked to the pump?
  4. Re: Central locking and courtesy lights
    I could be too late to offer any useful help ,since you asked about this in November.
    However, on my 80 (93 mod) central locking sometimes played up and rear fog lights and rev.
    lights misbehaved. I think the c l pump is in the boot as is the boot lamp (obviously).
    I discovered that the wiring to the facilities in the boot were shorting out to each other because the wiring had broken down at the point where there is a tight bend in the wiring near the hinge for the boot lid, between the points where it is clamped to the hinge plates.
    This, for me is the second time such a fault has happened on a '93 80. Regards dos.
  5. Re: Central locking and courtesy lights
    Got a central locking pump off ebay. Everything working again. Thanks for the replies!
  1. courtesy lights problem
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2008, 12:16 AM
  2. Puddle Lights and courtesy lights not working
    By PerArdua in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2008, 01:43 PM
  3. Coverting Central Lockin to Remote Central Locking
    By hoedawg in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2007, 05:08 PM
  4. Courtesy Lights Stay on?
    By Ruby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-07-2007, 12:23 PM
  5. central locking?
    By parailo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-07-2007, 11:53 PM
