Thread: open door warning
Results 1 to 10 of 17
  1. open door warning
    Mar 2008
    Not sure what to make of this..
    this morning, the 'open door' warning light came on for the driver door. i double checked this and it was definitely closed, tried opening/closing the door, this had not effect. though id leave it till after work tonight to have a check. when i got to work, i tried closing the locks via the remote and the doors would not shut via the remote i.e. clicking the shut button would not do anything!
    so i closed by hand/key. tried to reopen with remote again, the driver door opens, but no other door.
    from this point, i am unable to close any doors via the remote, have to do by key manually.
    are the two problems linked?
    both started this morning.
    Thanks.
    b5.5 1.8T Sport (2001)
  2. Re: open door warning
    Norfolk
    Remote locking of doors is via the CCM under the passenger front carpet. Do a search on here for CCM and wet carpets.
  3. Re: open door warning
    Mar 2008
    thanks, ive always cleaned out the plenum chamber when i do the annual service. so no wet carpets for me.
    how much can i expect to pay for the CCM to be replaced..roughly?
  4. Re: open door warning
    Norfolk
    It is usually a wire fault rather than CCM fault. A good VCDS read might give you a hint.
  5. Re: open door warning
    Mar 2008
    hmm.. ok, i'll get the vagcom hooked up tonight and report back.
  6. Re: open door warning
    Mar 2008
    i checked again throughout the day, with no change. i also checked the button on the remote for the boot. pressing this does not open the boot either.
    vagcom reported the following:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    01320 - Control Module for Climatronic (J255)
    49-10 - No Communications - Intermittent
    Does this show anything up?
  7. Re: open door warningNot sure what to make of this.. this morning, the 'open door' warning light came on for the driver door. i double checked this a
    Jun 2006
    UK, Mids
    Try disconnecting the battery. I have had similar lock troubles a couple or three times when I have recovered from a flat battery after leaving the coolbox plugged in. Disconnecting and reconnecting reset the CCM.
    Audi A8 - 2015 - 3.0TDI
  8. Re: open door warningNot sure what to make of this.. this morning, the 'open door' warning light came on for the driver door. i double checked this a
    Norfolk
    You need to look at 046 convenience control module. It should have logged a remote locking fault. As snapdragon says, a low voltage can cause this.
  9. Re: open door warningNot sure what to make of this.. this morning, the 'open door' warning light came on for the driver door. i double checked this a
    Mar 2008
    i specfically ran the 046 convenience control module. however that came back with no errors!
    interestingly this morning, i noticed i am unable to unlock all doors from the remote, but then not able to lock anything via the remote.
    i can lock all the doors via the central locking switch internally from the drivers door side panel (where all the controls for the windows are)
  10. Re: open door warningNot sure what to make of this.. this morning, the 'open door' warning light came on for the driver door. i double checked this a
    Norfolk
    That suggests either the remote has packed up or the fault is the aerial connection to the ccm. The ccm won't report a fault if it never gets a signal.
  1. Passat boot keeps clicking open.
    By Tomo 21 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-12-2017, 12:13 PM
  2. How do I open the petrol cap?
    By macker6464 in forum Golf MK6 - 2009 - 2013
    Last Post: 21-04-2010, 08:36 PM
  3. How To Open 03 Passat passenger door
    By Roy B in forum New Member Introductions
    Last Post: 05-11-2009, 02:59 AM
  4. How does the Quattro system work?
    By webchem in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 01-07-2007, 04:44 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
