Thread: 2.5tdi engine cuts off for no reason!?
  1. 2.5tdi engine cuts off for no reason!?
    Jul 2007
    I have a 1998/9 2.5tdi manual. For no apparent reason the the big red brake warning light comes on in the middle of the dash, i hear 3 bleeps, and the engine just cuts off. This has happened on the motorway in the 3rd lane - and I think as it was in gear it just jumped itself and kept going.
    In town this is risky as there is no warning and has happened at junctions etc.
    I have checked the manual and it just mentions brake fluid or ABS - but both are fine.
    Any ideas on why the car just cuts off? After 10 - 15 minutes, it's fine again.
    Thanks - and i hope your christmas has been better than mine!
  2. Re: 2.5tdi engine cuts off for no reason!?
    131 Post(s)
    1973 Post(s)
    You need to get a fault code read carried out on the engine and the ABS; this will possibly say you have a brake light switch fault.
  3. Re: 2.5tdi engine cuts off for no reason!?
    Jul 2007
    Thanks, will look in to this and report back...
  4. Re: 2.5tdi engine cuts off for no reason!?
    Jun 2006
    UK, Mids
    By cuts off, do you mean loses power? This could be the brake light switch, next time it does it, try lifting the pedal gently up with your foot. If power returns, it may be the switch (two switches in one housing actually)
  5. Re: 2.5tdi engine cuts off for no reason!?
    131 Post(s)
    1973 Post(s)
    Snapdragon, did you miss this bit?
  6. Re: 2.5tdi engine cuts off for no reason!?
    Jul 2007
    I purchased a fault code reader and the code is as follows:
    01203 - Electrical Connection between ABS and Instrument Cluster
    This I am lead to believe is actually the electronic box attached to the side of the ABS that needs to be repaired (about £125.00)
    Having investigated this scenario, it still does NOT explain why after 3 bleeps the engine cuts off totally leaving me with no power, steering, brakes etc.
    Any views on either of the above?
  7. Re: 2.5tdi engine cuts off for no reason!?
    131 Post(s)
    1973 Post(s)
    No fault codes on the engine?
  1. VW Polo 1.4FSi Engine cuts out
    By Haggarj2 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-10-2007, 03:49 PM
  2. Engine Cuts out / Wont Start
    By james_101 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-10-2007, 10:16 AM
  3. Engine cuts out
    By polopearl in forum Polo - Derby - Lupo - Fox
    Last Post: 01-06-2007, 07:05 PM
  4. engine cuts out while drivin
    By simon74 in forum Archive posts
    Last Post: 18-02-2007, 01:09 AM
  5. Engine cuts out on Mk 3 Golf TDI
    By Paul C in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-04-2006, 06:44 PM
