Thread: mk 3 TDi loss of power
  1. mk 3 TDi loss of power
    Dec 2007
    Hi, hope someone can help. My 97 mk 3 TDi occasionally has a complete loss of power when driving - if you keep the throttle to the floor it dies. If you take your foot off the throttle and dip the clutch for a few seconds, then try to rev it, it is fine again, and never seems to stall. What could this be?
  2. Re: mk 3 TDi loss of power
    2022 Post(s)
    Hello and welcome to the forum. The first thing you need to do is get a fault code scan done and this will probably show you have a faulty brake light switch.
  3. Re: mk 3 TDi loss of power
    Dec 2007
    Faulty brake light switch? How would this affect the running of the engine?
  4. Re: mk 3 TDi loss of power
    2022 Post(s)
    TDI engines have no throttle cable, instead it is known as Drive By Wire. The system has a safety cut out so that in the event of the accelerator and brakes being applied, the power is cut. If the switch is faulty, you would get this code,
    00741 Brake pedal monitoring implausible signal
    The possible reasons being
    1) Brake light switch (F) defective
    2) Brake pedal switch (F47) defective
    3) Both switch positions not synchronised
    The result being the glow plug warning lamp flashes or the brake lights not working and sometimes a loss of power.
  5. Re: mk 3 TDi loss of power
    Dec 2007
    sounds interesting, will investigate. Cheers for the info!
  1. power loss
    By dkny in forum Archive posts
    Last Post: 15-11-2007, 04:21 PM
  2. Power Loss
    By Audi4Life_28 in forum New Member Introductions
    Last Post: 31-10-2007, 01:24 AM
  3. power loss
    By ethers14 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2007, 05:54 PM
  4. Loss of Power
    By vinut21 in forum Chat - Anything with wheels
    Last Post: 23-06-2007, 12:03 AM
  5. a6 power loss
    By David in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-06-2007, 10:29 AM
