Thread: error 0050 start of injection timing
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: error 0050 start of injection timing
    #21
    Dec 2007
    brand new lifters and valves, no wear on cam. its not a cam rattle its if the timing was too far advanced making that heavy diesel knock wereas ive got the pump timing spot on using vag come. its exact on the middle line.
  2. Re: error 0050 start of injection timing
    #22
    135 Post(s)
    2036 Post(s)
    Are you getting the error code still?
  3. Re: error 0050 start of injection timing
    #23
    Dec 2007
    just getting n75 fault and in limp mode still got to change that and check the actuator arm on turbo
  4. Re: error 0050 start of injection timing
    #24
    135 Post(s)
    2036 Post(s)
    The next step is to remove the injectors and have them flow tested. Have you had the head off this engine?
  5. Re: error 0050 start of injection timing
    #25
    Dec 2007
    when i got car the belt had slipped and took out 4 inlet valves. the head was rebuilt with all new parts complete apart from the injectors. basic timing and dynamic is spot on
  6. Re: error 0050 start of injection timing
    #26
    135 Post(s)
    2036 Post(s)
    When did this noise start? Did you do the head?
  7. Re: error 0050 start of injection timing
    #27
    Dec 2007
    engine was loud as soon as it started it went quiter as i retarded the pump timing with vag com. ive got it spot on with vag com but can go further back but left it on the center line
  8. Re: error 0050 start of injection timing
    #28
    Bern, Switzerland
    I was finally able to check the error codes on my Sharan (AFN 1.9 TDI '99) this weekend and found the 00550 code on the engine controller.
    With the TDIgraph and engine idling heated to 82 degrees I get a timing off the scale at 203.
    Quick question as this seems a lot, the car runs however it is very sluggish and noisy but otherwise OK. Is that possible with this timing or should I look at the N108 valve ?
    Next question, is it possible that the range on moving the injection pump able to cover this difference or is it likely the belt is off by a notch ?
    I've checked the resistance on the lift valve, which was just in scope at 116.4 ohms.
    Thanks for any help .. 8-)
  9. Re: error 0050 start of injection timing
    #29
    135 Post(s)
    2036 Post(s)
    Try moving the pump but you should really check the cam timing first.
  10. Re: error 0050 start of injection timing
    #30
    Dec 2007
    sorry i cant help as im new to tdi units but learning very fast.
    my car has very loud intake noise how i dont know as all pipes are on and secure.
    been working it out that the car has a very harsh coarse engine noise weras my mates is sort of soft muted niose and lovly to drive.
    getting to the point on mine i wish i kept my petrol galaxy as driving it about sounds like them old post office ldv vans they ran about in
  1. Golf TDI injection timing - starting problem
    By Robble in forum Golf MK3 - 1993 - 1999
    Last Post: 19-11-2007, 06:05 PM
  2. fuel injection pump timing T4 1.9 TD ABL
    By Volkner in forum The Commercial Range
    Last Post: 18-09-2007, 10:16 PM
  3. Where's injection pump timing hole?
    By mistuart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-05-2007, 07:24 PM
  4. 1999 Golf 1.9 TDi injection pump timing
    Last Post: 13-05-2007, 07:26 PM
