Thread: Main headlamp failure
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Main headlamp failure
    Dec 2007
    Arghhhhh can someone help me please.
    Have checked bulbs which are ok, but do not know which relay operates them can anyone describe where or what number the relay is.
  2. Re: Main headlamp failure
    portsmouth
    check above post!!!merry crimbo
  3. Re: Main headlamp failure
    Dec 2007
    i would not be that bothered but as i have to get my son back to his bitch of a mums for christmas i am running out of ideas. fuses are ok, shorting out at lamp end, switch looks ok
  4. Re: Main headlamp failure
    portsmouth
    please dont swear my old ears cant take it neither the forum moderator
    have you checked with a volt meter, do you have power at the headlight connection????
    sticky
  5. Re: Main headlamp failure
    Dec 2007
    have checked with voltmeter no power to the lamps, side lamps work and main beam but main headlamps do not
  6. Re: Main headlamp failure
    135 Post(s)
    2039 Post(s)
    There is only a relay on cars that had the recall and this is usually behind the switch but as it was a retro fit, it can be all over the place. The most common failure is the switch itself. Is everything else on the car working such as wipers and heater blower?
  7. Re: Main headlamp failure
    portsmouth
    good a man who know his stuff will leave you with crasher
    crasher merry christmas thanks for bialing me out
    sticky
  8. Re: Main headlamp failure
    Dec 2007
    everything else is working apart from what i have mentioned. went to vw and they said relay 24 which of course they do not have in stock but i could not see anything marked 24 anyway arghhhhhhhhh
  9. Re: Main headlamp failure
    135 Post(s)
    2039 Post(s)
    What year is your car and which model?
  10. Re: Main headlamp failure
    Dec 2007
    it is an R reg 1600 GL
  1. VW Golf 1.9 TDi Headlamp Failure
    By Toey in forum Golf MK3 - 1993 - 1999
    Last Post: 24-12-2007, 04:01 PM
  2. Main Dealerships
    By timo'sullivan in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-07-2007, 09:42 PM
  3. Passat xenon headlamp leveller failure
    By jetski39590 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2007, 05:33 PM
  4. No main beams?
    By WJI8985 in forum 80 - 90
    Last Post: 01-07-2007, 06:52 PM
  5. 2001 Passat Main Headlamp Lamp Change
    By robbytdi in forum Archive posts
    Last Post: 09-01-2006, 08:14 PM
