Hi, Have a problem with diesel leak around top of the inlet manifold. Have had the manifold removed from head. When cranking over engine, diesel spurts out of what seems to be a small hole between ports possibly tracking up rough casting of inlet manifold. Is this a machine casting hole which has an interference fit ball bearing which is not sealing, causing the problem? Does anyone have a solution to this problem?
