Thread: Interior lights problem
  1. Interior lights problem
    Hope someone can help with this problem?
    My interior lights work fine when switched on but they don't come on when the car is unlocked or when the doors are opened (the footwell lights do though)
    As its a problem with both doors i can't imagine it being a door switch fault - is there something else to look for?
  2. Re: Interior lights problem
    Hi I have experianced this problem once and the onboard supply control unit was the fault.But the first thing you need to check is the interior light itself
  3. Re: Interior lights problem
    The light works fine if it's switched on and the footwell light come on when the doors are opened
    what do you mean by checking the interior light?
    cheers
  4. Re: Interior lights problem
    Hi When you switch on the light, that is one function, but when the switch is on doors open, that is another function.It can work on the one and not on the other.If you can get the loan of an interior light and swap them,you can check it that way.The fact that the footwell lights work suggests the micro switches in the door locks, which activate the interior light, are ok.
  5. Re: Interior lights problem
    Dec 2007
    Any luck? Looks like my Audi 80 has a similar problem - checked all the door switches and they seem OK. The light comes on when I slide the switch to "on" but doesn't come on when I slide it to "door" position and open a door...
    1998 S reg VW Golf S MK4 TDI 90 (1.9 66KW AGR) 130K miles
    1994 M reg audi 80 Sport SE (2.0 8V ABK) 111K miles
  6. Re: Interior lights problem
    Haven't managed to find a new light unit (sunroof model) to try yet - if you manage to try 1st please let me know
  1. interior lights
    By gibo.drum in forum Chat - Anything with wheels
    Last Post: 18-02-2008, 09:43 PM
  2. interior lights
    By stevie j martin in forum Golf MK4 - 1999 - 2004
    Last Post: 20-01-2008, 01:34 PM
  3. Interior lights
    By enders500 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2007, 09:26 PM
  4. Interior Lights.
    By Jez. in forum Passat - Archive Topics
    Last Post: 17-04-2007, 04:56 PM
  5. VW SHARAN VR6 (96) INTERIOR LIGHTS PROBLEM
    By alanled in forum Archive posts
    Last Post: 26-06-2006, 02:02 PM
