Thread: ABS warning still on
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. ABS warning still on
    Chinnor, South Oxfordshire
    I've had the ABS warning lights come on with the 3 warning beeps for some time now. So far I've tried the following:
    - VW garage told me it needed a new ABS control unit. I have fitted a new one, the warning lights did not go away.
    - I read the fault codes and got two: rear O/S ABS sensor fault and O/C brake light switch.
    - Today fitted a new ABS sensor. Read the codes again; got one with rear O/S sensor intermittent connection (could have been caused by fitting the sensor?). Reset the codes.
    - Still got the warning lights on. Took the car for a spin, stopped, read codes again - nothing - but still the warning lights are coming on.
    Anyone any ideas? I talked to the people who sent me the replacement ECU, they said send it back and they will test it, which I guess is the next thing to try?
  2. Re: ABS warning still on
    Jun 2006
    UK, Mids
    Did you replace the brake light switch?
  3. Re: ABS warning still on
    Quote Originally Posted by snapdragon View Post
    Not yet... the one I got turned out to be the wrong sort.
  4. Re: ABS warning still on
    Dec 2007
    yep had that problem, brake switch replaced all ok now. one thing to check does the abs light only come on after you have braked ?.
  5. Re: ABS warning still on
    Quote Originally Posted by FLIPKEY View Post
    No - it comes on when you turn the ignition on, then stays on.
    I'm a bit puzzled as one the original fault codes was an open circuit brake light switch, now why would that cause an ABS error?
  6. Re: ABS warning still on
    OK had the brake light switch off and tested it and its working fine. So I can only assume that the ABS control unit I replaced is also faulty? Or could there be another reason?
  7. Re: ABS warning still on
    Dec 2007
    I had the same thing , also the ESP light would come on , I know you have checked your brake switch , but do both of the brake lights work?
    I tested my brake switch and it seemed ok , but as they were only £8 I fitted a new one and replaced my brake light bulbs and they problems went away , that was 20k ago
  8. Re: ABS warning still on
    Hi Was just wondering if the replacement abs control unit has the same coding as your old one? And you can check the signals from the wheel sensors in measured value blocks to make sure these are ok.
  9. Re: ABS warning still on
    Quote Originally Posted by kenney View Post
    The ABS replacement unit is the same part number as the original, is that what you mean by coding?
    How do you check the signals from the sensors? Is that something you can do with vag-com?
  10. Re: ABS warning still on
    No the part number may be the same but the coding can be differant,you can check the sensor signals in measured value blocks for the break system iam sorry iam not familiar with vag-com so i dont know which channel you need, perhaps Crasher gan help you there
  1. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  2. EPC Warning light
    By 12bamf in forum Beetle 2000-
    Last Post: 18-11-2007, 02:13 PM
  3. ABS Warning
    By miniman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-08-2007, 05:43 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  5. ECU Warning Light
    By Gavin78 in forum Passat - Archive Topics
    Last Post: 02-04-2007, 12:51 PM
