Thread: camber alignment figures
  1. camber alignment figures
    My front tyres wear heavily on the inside shoulders. Having read other posts here I am going to check/adjust the camber.
    Does anyone know what the correct camber alignment figures are for an 03 1.8t avant?
    Boz
  2. Re: camber alignment figures
    CHESHIRE
    You can only equalize the camber between lefr/right by moving the subframe
    sound like your tracking/toe is toeing out too much if both tyre are wearing the same .bear in mind the A4 needs the raised toe checking to prevent bump steer occuring-not normally checked by your tyre company .i.e kwik fit/halfords
    camber approx 25/30minutes negative /each side
    toe in10 minutes per side= total toe20 min+/-4min
  3. Re: camber alignment figures
    thanks for that
    Do you know what the tracking numbers are too?
    Looks like i have to check it all just to be sure.
    Thanks in advance
    Boz
  4. Re: camber alignment figures
    Ah
    You may already have answered that question
    Sorry
    The un inisciated!!
  1. will i need a camber kit
    By kinghustler in forum Chat - Anything with wheels
    Last Post: 08-11-2007, 08:10 PM
  2. Camber, toe and tyre change?
    By Big G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-10-2007, 07:10 AM
  3. Camber Specifications
    By Silver in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-07-2007, 09:55 AM
  4. Camber alignment - is it a big issue
    By blairmiller166@ in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-06-2007, 12:11 PM
  5. How do I adjust camber?
    By victorwhiskey in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-10-2006, 07:10 PM
