Thread: rear light bulb change
Results 1 to 10 of 10
  1. rear light bulb change
    arctic blue Guest
    not that bulbs have failed yet,but, any idea how to change /get access to rear of light unit in boot. lights on the bootlid have a cutout in lining for access. looks to me that the complete side panel linings in boot have to be removed for the stop, tail, indicator bulbs to be changed . or is there some other way, staring me in the face.
    awaits response
  2. Re: rear light bulb change
    Dec 2007
    hey!
    As far as i am aware you cant change those lights, due to the fact that they are a ring of LEDs rather than one bulb! The reversing lights and the fog can be replaced I think cause they are one bulb but if they brake, tail and indicators fail it will probably have to go to a *******!
    I am be wrong but this is my understanding!
  3. Re: rear light bulb change
    Feb 2007
    Huddersfield
    Yes, the rear lights are LEDs and are supposed to be guaranteed for the life of the vehicle, as are the indicators in the mirrors.
    If you look closely at the rear lights you'll see they are made up of quite a few LEDs, not just one so I would imagine you could lose a few without any problem.
    Iain
    Car - 2006 VW Passat 2.0TDi SE Estate.
  4. Re: rear light bulb change
    Apr 2007
    France
    12 Post(s)
    Mine (saloon) has a cut out panel on each side of the boot liner to allow access the rear lights.
  5. Re: rear light bulb change
    Jul 2007
    When my wife dropped me off this morning I noticed that the passenger side brake light wasnt working,, if these are LED's could it be a loose wire?,, also would a bulb faliure light come on in the dash?
  6. Re: rear light bulb change
    Norfolk
    Rear indicator, tail light and brake light are LED clusters instead of bulbs. Each "bulb" is a collection of LED's arranged in bunches of 4. The ECU allows for failure of up to 4 LED's before flagging a fault. (In theory). Main problem is that if 1 LED fails, it sometimes takes out all 4 in the bunch. This loss of 4 puts a strain on the others and they go shortly after. In theory LED's last a long time. Anyone with LED Christmas lights will know this is not always true.
  7. Re: rear light bulb change
    arctic blue Guest
    shropslad,
    never had a rear light out yet. but funnily enough a front dip beam went on me last week. i was pleasantly surprised with the dash message. fr l/h dip bulb failure, and an orange bulb icon flashed up too. damn clever. i was even more surprised at how easy it was to change. just push fit.
    washer fluid empty, tyre pressure low, service due. great stuff.
    i wonder what would come up if it knew front tyres were on limit, wipers need renewing, 33k on clock, and good wash needed. TIME TO SELL THE CAR.
    i take delivery of new golf thursday.
    enjoy your passat lad, i certainly did
  8. Re: rear light bulb change
    Jan 2010
    Horley
    but if i need do remove the rear light, how can i do it?
  9. Re: rear light bulb change
    Norfolk
    Saloon...pull off trim cover, undo three nuts, take off connector, pull light unit off from outside. Estate...open tail gate , pull off black bit of trim next to light, remove one nut and connector Pull and push towards outer edge. Swear alot until it comes off. (bit of black plastic trim may break).
  10. Re: rear light bulb change
    Jan 2010
    Horley
    Quote Originally Posted by martin1810 View Post
    Thanks, done it with alot of swears
  1. How do you change the bulb in the boot/trunk light of a Mk4?
    By torvill84 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-04-2014, 09:00 PM
  2. Replies: 2
    Last Post: 07-08-2010, 04:25 PM
  3. Replies: 3
    Last Post: 04-01-2008, 12:59 AM
  4. How do you change a bulb?
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-10-2007, 07:22 AM
  5. Changing Rear brake light bulb
    By jon123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:48 AM
