Thread: Heater is getting hot after 30 miniutes!
  1. Heater is getting hot after 30 miniutes!
    Dec 2007
    this is my first post, looking forward to hearing from you.
    my Audi A4 '2000 TDi is doing ok except heater.
    It cannot blow hot air even though heater is on HI.
    It starts to blwoing hot air after 30-40 minutes when I already got to work with hat and scarf and gloves on.
    any idea what I should look at?
    p.s to be honest I am just ordinary girl who hasn't got much knowledge about a car...
  2. Re: Heater is getting hot after 30 miniutes!
    134 Post(s)
    2009 Post(s)
    This is common on modern diesel engines as they are so efficient they produce little heat. There are glow plugs in the heating system that are supposed to boost the heat output and these could be faulty so they need to be checked that they are working and low heat output could also be down to a blocked cooling system or faulty water pump so for peace of mind have it checked over. When I take a customers TDI home at this time of year, it is rarely warm by the time I get to work in the morning, which can take 45 minuets in traffic.
  3. Re: Heater is getting hot after 30 miniutes!
    Mar 2007
    Surely the glowplugs are just to assist cold starting? I didn't think they had any effect on cabin heating.
  4. Re: Heater is getting hot after 30 miniutes!
    134 Post(s)
    2009 Post(s)
    On the back of the head there is an aluminium housing that contains three glow plugs that are very similar to those used in the engine. These are controlled by the engine ECU when required, to the boost the temperature of the water entering the heater matrix.
  5. Re: Heater is getting hot after 30 miniutes!
    joe-9o Guest
    HI, renew the thermostat , it will have stuck in the open postion- hope you find this helpfull.
  6. Re: Heater is getting hot after 30 miniutes!
    134 Post(s)
    2009 Post(s)
    Have you seen the date of his post?
  1. A4 td1 heater/air con fan.
    By A4 fatboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-12-2007, 04:42 PM
  2. Pre-heater at 5c or less
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-10-2007, 10:38 AM
  3. Heater Fan
    By Brainscram in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-10-2007, 08:00 AM
  4. Heater aux heater?
    By Dave Avant in forum Audi A4 - Archive Topics
    Last Post: 08-02-2007, 03:43 PM
  5. Heater motor A4
    By kered389 in forum Archive posts
    Last Post: 08-01-2007, 09:18 PM
