Thread: A4 2001 abs/transmission fault
  1. A4 2001 abs/transmission fault
    Dec 2007
    • hi got 2001 a4 auto. trans is in limp mode, abs light on dash flashing at me. garage fitted exchange abs ecu. still got fault cant get mot due to light on they have told me it is probably an earthing fault? somewhere in wiring anybody had simular fault help! there is canbus communcation faults from trans & abs in fault codes & they wont clear
  2. Re: A4 2001 abs/transmission fault
    May 2007
    Sometime two modules with faults lock each other out when the bus reboots.
    First try disconnecting battery for a minute ( hope you have radio code if needed)
    Then see if it resets.
    If not disconect battery, and then ABS, reconnect battery and try to reset transmission.
    then disconnect battery, reconnect ABS and try reseting that.
    Have known that to work.
    You will need a copy of VAG-COM and the correct lead for your car.
  1. 2001 Passat TDi 130 Engine running fault nightmare
    By Passatnightmare in forum Chat - Anything with wheels
    Last Post: 05-08-2008, 08:48 PM
  2. A4 2001 Speed Sensor Fault
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2007, 06:48 PM
  3. golf gti 2001 fault codes
    By zoebunny in forum Archive posts
    Last Post: 18-10-2007, 09:09 PM
  4. 2001 A4 2.0 ALT fault codes
    By Lurcherboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2007, 02:47 PM
  5. A4 2001 instrument fault code
    By Dozz in forum VCDS - General Questions
    Last Post: 22-06-2007, 08:48 AM
