Thread: Tiptronic Gearbox Problems...
Results 1 to 10 of 13
  1. Unhappy Tiptronic Gearbox Problems...
    Aug 2007
    I was doing 70 on the motorway when a thud was heard but the car was still going, when I slowed down at the junction, almost nothing, no power when starting off again.
    Its like 1st gear has disappeared, now when you pull off you rev the engine, a while later a thud and the car slowly pulls off.
    Also when selecting other gears it occasionally thuds into them and then starts moving including REVERSE.
    The gear indicators on the dashboard are all inverted and all are hightlighted. I've tried a ECU reset by dis-connecting the battery for 5 minutes but the fault comes back on.
    Anybody got any ideas? Is my Gearbox caput? or is it the ECU? or something else(Tiptronic brain, etc)?
    I've been looking around for a replacement gearbox but at £400 for a S/H plus fitting I want to be sure before paying up.
    Paul
  2. Re: Tiptronic Gearbox Problems...
    133 Post(s)
    1990 Post(s)
    Which box is this, auto or CVT? The code is in the service book.
  3. Re: Tiptronic Gearbox Problems...
    Aug 2007
    The code is down as:
    X2A BON COV GOF H6S JOR M3L Q2J
    It is the 115bhp PD Model if that helps.
    I think its just the Auto not the CVT as CVT is a new thing I thought.
    Paul
  4. Re: Tiptronic Gearbox Problems...
    Aug 2007
    Found some more info:
    GS EU3 AG5 ATJ
    This definitely relates to the gearbox.
    Paul
  5. Re: Tiptronic Gearbox Problems...
    Dec 2007
    West Sussex
    If you are hearing a thud than it "sounds" like a mechanical problem rather than an ECU.
    Have you put the car on diagnostics to check for error logs?
    If I was you I wouldnt drive the car any more until the problem is diagnosed. If you are hearing thuds there may be physical damage.
    Rob
  6. Re: Tiptronic Gearbox Problems...
    Aug 2007
    I was under the impression that the tiptronic gearbox was under the control of the ECU.
    When the ECU was reset it worked properly for about a minute before the fault re-occured.
    When you put it into 2,3,4th or Reverse it seems to work just not in Drive, even though now its doing the same for 2 as well. Takes a while to kick in put eventually starts to move.
    I did get it delivered back home instead of driving it at £100 by the AA so not to cause more damage.
    Paul
  7. Re: Tiptronic Gearbox Problems...
    Dec 2007
    West Sussex
    You should have asked the AA to do a diagnostics check on it. Maybe the ECU would've shown faults. Anyways, if you're saying the car worked find after a cold reset there may be a chance there is a fault with the ECU. Get it diagnosed.
    Rob
  8. Re: Tiptronic Gearbox Problems...
    133 Post(s)
    1990 Post(s)
    ATJ is the engine code, the box will be an ERY. I would suggest an oil and pan filter change first, a new VAG box is just under £2000.
  9. Re: Tiptronic Gearbox Problems...
    Aug 2006
    cheshire
    had a beemer auto once,slow to drop into gear n get going,it was the filter in the autobox blocked up.sealed for life box on it(apparently)but local specialist sorted it,fine after that,at 233k too!
  10. Re: Tiptronic Gearbox Problems...
    Aug 2007
    Hi easylifeauto,
    What is meant by 'filter in the autobox' not sure what you are refering to?
    milenia
  1. Tiptronic gearbox fault
    By ProfDMW in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-02-2008, 09:15 PM
  2. Auto/tiptronic gearbox ecu problem
    By jewelldo in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 09:57 PM
  3. A6 4x4 180hp 2000 tiptronic PROBLEMS HELP!
    By jetpipe in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-06-2007, 04:08 PM
  4. Replies: 3
    Last Post: 24-03-2007, 11:11 PM
