Hi, this is my first post here.
I've been having this problem since last month, most of the time when i'm changing up or down gears between 1st - 4th gears, the car jerks momentarily. Its more noticable at lower gear changing,after changing the appropriate gear its runs fine in that gear. Changing to 5th gear at higher speed seems to be fine. I have taken it to local garage, replaced leads with audi ignition leads and also Air Mass Flow Meter, but jerking persists. any advice is appreciated..
