Thread: New A3TDi Owner!
  1. New A3TDi Owner!
    Dec 2007
    Hi everyone,
    I am now the proud owner of a 2000 A3TDi 110.
    A few questions...
    What should I expect to pay for a Cambelt Change (near Basingstoke)
    I thought it might have a MPG/trip computer but obviously not!
    Best place for accessories, floor mats, I-pod connection etc, I've tried flea-bay.
    Anything else I should know?!
    Rich
  2. Re: New A3TDi Owner!
    135 Post(s)
    2038 Post(s)
    Don't shop by price on this job. You should ask questions about what will be done and insist on the water pump being changed, the use of G12+ coolant, which bolts will be replaced (that must be the engine mount to body bolts at least and preferably the consul to block bolts as well) and also ask if a Commencement Of Injection (COI) plot can be provided with the receipt at the end of the job and if you are met with looks/sounds of puzzlement, walk away/put the phone down.
  3. Re: New A3TDi Owner!
    Dec 2007
    Excellent advise, thankyou!
    I'd better find out what a COI plot is myself first then!
  4. Re: New A3TDi Owner!
    135 Post(s)
    2038 Post(s)
    The Commencement Of Injection timing is set using a graph and plotting the COI against fuel temperature (and therefore density) and is a very difficult thing to get absolutely dead on when working on a later VEP TDI engine as for each adjustment, the engine has to be turned off, the injection sprocket bolts loosed and the pump sprocket centre bolt advanced or retarded as necessary. The amount of movement required for a huge change on the readings is tiny and you spend a lot of time shooting either side of the target reading. VAG-COM has an excellent function for this which shows the graph on the screen http://www.ross-tech.com/vag-scope/TDIGraph.html, VW’s method is on a look up graph using live data fields. Note that on some cars the sprocket bolts must be changed if they are released and this is determined by the type of bolt used.
  5. Re: New A3TDi Owner!
    Dec 2007
    Great help thankyou.
  1. new A4 cab owner
    By navman in forum New Member Introductions
    Last Post: 08-03-2009, 11:26 PM
  2. new R32 owner saying hi
    By gazjones in forum New Member Introductions
    Last Post: 02-09-2007, 10:48 PM
  3. Maybe....A3 Owner
    By jimny33 in forum Audi A3 - Archive Topics
    Last Post: 22-08-2007, 10:43 PM
  4. New A6 Owner
    By johnpen in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-01-2007, 10:55 PM
  5. Hello all - new EOS owner here!
    By Caddy Van Man in forum Eos
    Last Post: 04-01-2007, 01:32 AM
