Thread: ESP Trouble
Results 1 to 8 of 8
  1. ESP Trouble
    Dec 2007
    Hello all,
    Recently bought a 2003 Audi A3. Really good car but every so often the ESP warning light comes on after a few miles driving. On other occassions I can drive 50 miles and it doesn't happen. Can anyone explain why this might happen or what the likely cost would be to get it sorted?
  2. Re: ESP Trouble
    131 Post(s)
    1976 Post(s)
    It will probably be an acceleration sensor fault but you need to get the ABS fault code read to see what is stored.
  3. Re: ESP Trouble
    Jul 2007
    Cheshire, or my A6
    I am assuming it illuminates and stays on until you re-start? Is this true? My A6 did it once, which gave me a bit of a surprise, but my mate had an A3 which was doing the same. The ABS sensor on the rear was replaced and it was sorted. But before you go changing sensors and all that, just check the ABS wires etc are not trapped or corroded, as I've heard they can get trapped and cause the faults you are describing.
    Good luck!
    Paul
  4. Re: ESP Trouble
    i have a 2002 a3 tdi sport which had this fault especially when cold. It was the number 2 cylinder pump injector, cost £700 to repair and now its gone again. Now entering warranty battle with dealer and audi UK. Going through car history this is the third one in 4 years all at main dealers all paid for.Great warranty system!
  5. Re: ESP Trouble
    131 Post(s)
    1976 Post(s)
    The third one on the same cylinder or different cylinders?
  6. Re: ESP Trouble
    Quote Originally Posted by paul b View Post
    Good luck!
    Paul
    Ignore me, I can't read the rules
  7. Re: ESP Trouble
    Oct 2005
    Quote Originally Posted by VAG.Direct View Post
    READ THE RULES!
    You have been told in this thread here that if you wish to advertise you must pay.
    One more post from you advertising your wares and you will be banned.
  8. Re: ESP Trouble
    Jul 2007
    Cheshire, or my A6
    Go on Sam, lay down the laws!
  1. mk 2 weber co trouble
    By jungleboystu in forum Golf MK2 - 1984 - 1992
    Last Post: 28-11-2007, 09:55 PM
  2. LT trouble
    By maggotrunner in forum The Commercial Range
    Last Post: 23-09-2007, 09:58 PM
  3. gti trouble!!!!!!!!!
    By wadi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-05-2007, 12:00 PM
  4. HELP!!! mk4 golf gti trouble
    By wadi in forum Golf MK4 - 1999 - 2004
    Last Post: 27-05-2007, 10:42 AM
  5. Fan trouble.
    By Danozeman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-05-2007, 05:30 PM
