Thread: Clutch Sticking?
Results 1 to 10 of 16
  1. Clutch Sticking?
    Dec 2007
    The past 2 mornings on the way to work in my Mk4 PD150 it seems that the clutch didnt return to my foot on two occasions, and i had to flick the underside of it with my toe to make it return fully. It might just be me being paranoid because i only just bought the car, but have any of you guys heard/experienced anything like that?
  2. Re: Clutch Sticking?
    Canada
    could be a sticky cable, best to get it checked over
  3. Re: Clutch Sticking?
    Sep 2007
    Essex boy in Suffolk
    Quote Originally Posted by onzarob View Post
    MK4 have a hydrolic clutch, no cable. check the pedal box, see if that is sticking or broke
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  4. Re: Clutch Sticking?
    Hi If iam not mistaken here, it is a problem with the clutch pump.I think there is a modified pump which resolves this problem.It has no cable.
  5. Re: Clutch Sticking?
    Dec 2007
    Does that mean it is an intermittant problem caused by an iffy original clutch pump design?
    Or is it something that has happened with age, and the pump deffinately needs replacing?
  6. Re: Clutch Sticking?
    Canada
    Quote Originally Posted by Borab0y View Post
    oops
  7. Re: Clutch Sticking?
    Quote Originally Posted by woo View Post
    Sounds like a faulty master cyclinder, or maybe slave, or possibly the bearing sticking. Whatever the cause, get it checked asap, as whereas you notice the extremes when the pedal stays down, at other times the clutch may be part engaged and you don't notice - which is really really bad for the clutch. If its slipping under normal driving conditions, which it will do if part engaged, the heat build up will damage the flywheel too....
    I'm not aware of any common pedal box problems on the mk4... although also a possibility.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  8. Re: Clutch Sticking?
    I dont know, some of the cars we changed the pump on, were only a few months old and others were a couple of years,for some reason it was only the mk4 that seem to have had this problem
  9. Re: Clutch Sticking?
    134 Post(s)
    2022 Post(s)
    This is common; it needs a new master cylinder which is quite quick and easy to do. If people would bleed the clutch at the same time as bleeding the brakes (every 2 years), it would not happen so much.
  10. Re: Clutch Sticking?
    Dec 2007
    So i need to get this looked at. Do any of you know of a decent vw specialist in the south yorkshire/yorkshire area? or should i take it to a dealer and pay their prices?
  1. Sticking Clutch
    By Kaz G in forum Archive posts
    Last Post: 19-12-2007, 06:38 PM
  2. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
  3. Sticking
    By Jum in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-03-2007, 01:09 AM
  4. clutch sticking
    By maham31 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-06-2006, 08:51 AM
  5. Sticking Clutch Pedal
    By Sesame in forum Passat - Archive Topics
    Last Post: 31-05-2006, 11:39 PM
